Tuning for 212/218 high lift cam
Adjustment of the RAF table, Idle Spark tables, slight tweaking of the over/under speed idle spark correction, minor tweaking of the Proportional/Intergator idle parameters, VE table, MAF table (if desired). That is all I can think of, that I did to have my cam (low lift version) idle almost un-noticeably, pretty much like stock.
You'll find with that cam that it requires very little tuning. The spark table will require the most work. It will run fine on the stock tune, but need tuning to get everything out of it.
