tuners drilling the throttle body blade
Old May 11, 2012 | 08:54 PM
redsilv's Avatar
Default tuners drilling the throttle body blade
are tuners still recommending to drill the throttle body blade to
help with high idle issue?
i thought that was a sign of a **** poor tuner?
anyhow i believe that aint right,
my engine doesnt idle right so the tuner points fingers to anything but
his tune.
is this practice still going around?
he says he is using HP Tuners!
W T F !
Old May 11, 2012 | 08:55 PM
redsilv's Avatar
anyone got any input on this?
Old May 11, 2012 | 08:59 PM
2000chevysilverado's Avatar
My tuner says that's retarded to drill the hole out bigger
Old May 11, 2012 | 09:22 PM
Gadgetized's Avatar
It is in the tune. No need to drill.
Old May 11, 2012 | 09:27 PM
dirt track racer 81's Avatar
Tuner doesn't know how to idle tune. It generally cause more idle problems..
Old May 11, 2012 | 10:10 PM
brandon6.0's Avatar
I am running a Nelson tune and having the same damn problem. Very aggrevating pulling up to a stop and truck wanting to die. Yeah mine will be getting dyno tuned shortly.
Old May 11, 2012 | 10:22 PM
chevrolade's Avatar
only reason to drill is when not tuned and it will help it stay on till u go get it tuned
Old May 11, 2012 | 10:55 PM
Atomic's Avatar
I have a gauge for that
Idle is tougher on the DBC cars/trucks. If you have a huge engine that pulls a lot of vacuum you may need to drill it slightly, but not a ton. Basically the engine needs more air than the IAC valve can supply. On DBW TBs this is a non-issue. Notice on stock LS1s the TB is drilled...
On a side note, I bought my TB second hand, it was drilled, and my truck idles fine.
Old May 11, 2012 | 10:57 PM
skeet's Avatar
very true, i had to slightly drill mine cause the engine was pulling so much vacuum, no issues at idle neither
Old May 12, 2012 | 12:06 AM
tarinitup's Avatar
9 Second Truck Club
My dbc is drilled. It's not illegal just frowned upon.
