Truck vs FBody
Old Oct 3, 2007 | 01:47 AM
IslandTahoe's Avatar
Default Truck vs FBody
What are the differences between the Truck and FBody versions of the ECM and program?
My situation...I am planning on swapping a T-56 into my 00 Tahoe and ideally would like to use an ECM with a 00 Fbody VIN burned-in and the Fbody maunal harness. I already run Fbody injectors and I hope that the coil pack connector is the same. I want to get the separate IAT sensor.
The various tuning programs appear to be different for trucks and Fbodys, at least they claim to sell different versions for each. Is the hardware the same or are there subtle differences? I believe the PIN assignments may differ at the ECM or am I wrong?
I am going to be doing significant SD tuning anyway so I'm not too concerned about the stock Fbody tune. There should be very minimal if any controls on the T-56 from the ECM. Gearing and tire size can be changed.
Do I lose my gauge cluster? Maybe ABS?
Anybody have any experience or thought on this?
Old Oct 3, 2007 | 07:16 AM
Rhino79's Avatar
9 Second Club
THe PCM is identical between the 2. Only the calibrations are different. You would be better off to use your PCM and swap the Trans segment with a 6-Speed Segment from a 00 F-body PCM with the same Operating System number.
Your cluster will function correctly and all the wiring at the pcm is the same.
Old Oct 4, 2007 | 11:36 AM
Couple questions:
1) Can this swapping of trans segments be done with Edit?
2) Does a manual trans harness from an FBody directly swap over?
Thanks
Old Oct 4, 2007 | 11:40 AM
Quik's Avatar
5 year bitches!
your auto harness works with the t56, just search for offical t56 swap thread
Old Oct 4, 2007 | 02:19 PM
Yeah I saw that.
I have some connection issues with my current harness so I thought I could kill couple birds with one stone. If I were to find a new harness could I just get an FBody version (T-56 connections, clutch pedal connection, separate IAT sensor, FBody fuel injectors) and lessen the splicing I would have to do?
Old Oct 4, 2007 | 02:41 PM
Quik's Avatar
5 year bitches!
that would be more work then needed!!!!!!!!!!!!
no need to reinvent the wheel its already been done
Old Oct 4, 2007 | 07:03 PM
Sorry, but I don't understand what you are saying.
Is the short answer that the FBody harness does not fit/work? That using an FBody harness requires some sort of additional work? Tuning? Help with the "more work is needed" part. What is needed? Different PIN locations?
I know that I can use the truck harness, but I also know that route requires additional work also, as described in the swap thread. Was hoping that the FBody harness might require none.
Old Oct 4, 2007 | 10:06 PM
Quik's Avatar
5 year bitches!
the truck harness is the way to go. to make fbody work its completely different. its not worth any effort to make it work. to make the truck harness work its simple!!!! 5 minute of work for the truck one compared ot hours apond hours for fbody
the wheel has been invented. there is no need to reinvent it once again.....which means the path you choose has been done. there isnt a need to try and change thigns up when all the hard work has been done
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
