Truck stalling when put in gear.
This is my new 5.7 224/228 114 cam 243 heads 60lb inj for now 4l80e trans. Got it to idle at 850rpm when I shift it to reverse it dies. It idles ok but just dies when put in gear.
All that i have mess with is only trying to get ve in line i used a corvette ve stock table and base runing airflow table. ve was off a little so now it will idle but stft are still in -10 to -12. would like to get it a little lower before I use my wideband to fine tune it. Havent played with timing thought about adding a 2-3 degrees at idle. Didnt look at timing when I shift it into gear since it just dies.
Timing is at 26 when I shift in to gear. I added .3 across the board on start up initial airflow and 10% to base running airflow table. Starts much better but still stalls when put in gear. My stft are 0 to 6% now.
Didnt tune running airflow because ve was off I read that it must be good before you can tune RAF. Yes added 10% over stock and idle rpm in gear is at 850rpm.
It's kind of a back-and-forth thing. You've got to get it idling well enough that it doesn't stall on you constantly while tuning the VE, MAF, etc. Then once that's all good, do the RAF again.
