Truck died :(
Old Dec 8, 2011 | 05:15 PM
blwn4.8's Avatar
Exclamation Truck died :(
Not a chevy truck but nobody really checks dodge shstuff on my other truck (05 dodge ram) my battery terminals were loose and my truck died... Now I tightened the terminals and it dies sometimes at low speeds. Tested the alternator and it checked out good battery is good. What else can I check?? Multimeter in hand so tell me what to hook it up to!!
Old Dec 8, 2011 | 07:32 PM
david068513's Avatar
make sure they are tight and no corrosion and also check all the grounds.
Old Dec 8, 2011 | 08:12 PM
TXSZ66AVLANCHE's Avatar
So.....why the Dodge in the GM forum? If nobody checks the Dodge threads....lol
Old Dec 8, 2011 | 10:48 PM
1FastBrick's Avatar
Custm2500's Rude Friend
How Exacatly did you test the battery???
FWIW The battery needs to be load tested. If it has a bad cell it won't show up till its under a load. Some times even the old carbon pile load detectors wont pick up a defective cell. The best way is a digital battery tester. It simulates different loads and can detect problems a regular carbon pile tester can not.
Old Dec 9, 2011 | 05:36 PM
blwn4.8's Avatar
Digital tester at work and I hooked up the multimeter to the cables to test the resistance and it all checks out good :/
Old Dec 10, 2011 | 09:54 PM
5speedsilverado's Avatar
im no dodge expert, but my mom had an 04 ram that did the same thing, dodge has a reprogram for that, or at least that is what they told her, it is a very rare concern, they kept the truck for a week to figure it out. idk how they will deal with it cause your warranty may be up
Old Dec 10, 2011 | 09:56 PM
blwn4.8's Avatar
yeah, ill have to go ask! thanks guys!
Tig
Sep 30, 2015 07:39 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
fcompean
Jul 15, 2015 09:55 PM
GreyChevy
Jul 7, 2015 08:57 PM
