Transmission Trouble
Old Apr 30, 2013 | 07:40 AM
InsaneDomestics's Avatar
Question Transmission Trouble
I have an 08 CCSB 4.8
I can push my tow haul button and the light comes on the dash but it doesnt kick out of OD... Same thing happens with the Traction Control, light come on but it still doesnt disengage... Anyone know what might be causing this?
Old Apr 30, 2013 | 09:56 AM
Suburbazine's Avatar
Two things:
Tow/Haul doesn't disengage overdrive. It merely modifies the shift points and firmness.
Traction Control has 2 separate systems (3 on stability-controlled trucks), the button only disables 1 of them. So if the truck senses that overthrottle is causing wheelspin you will still get the throttle pulled out.
Old Apr 30, 2013 | 10:16 AM
Well wtf is the point of having the buttons? Is there anyway to completely disengage the traction control/stabilitrak?
Old Apr 30, 2013 | 11:24 AM
nonnieselman's Avatar
Go from a dead stop with and without the tow haul button on..
I set my tow haul button up to go to the lowest possible gear.. if im goin under 90mph it will drop down into 2nd gear.. under 50mph it drops to first..
Old Apr 30, 2013 | 04:25 PM
Z71crawford's Avatar
hold down the traction control button it turns off the traction control and the Stabliatrc ( or however you spell it)
calsdad
Jun 14, 2023 11:07 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
nabozny21
Oct 17, 2015 07:47 PM
jscherbs
Sep 30, 2015 07:54 AM
