Torque Management
Old Jan 29, 2007 | 02:41 PM
Tig's Avatar
Tig
This probably sounds stupid but here we go.
What does the torque management do? How does it slow the truck down?
Would the purchase of a programmer/tuner fix this?
Sorry if it sounds stupid, I am clueless when it comes to electronics.
Would mods like headers/exhaust, intake, throttle body, e-fans, pullies and maybe a high flow water pump and cooler thermostat help with this problem.
Thanks guys
Old Jan 29, 2007 | 03:07 PM
TarheelZ's Avatar
Torque management refers to the computer code that protects the rest of the drivetrain from the engine's torque. TM is what prevents you from spinning the tires from a dead stop and from barking the tires when the transmission shifts. A custom-tuner can 'remove' this torque management by changing some of the program parameters as mentioned above, but I do not know of any handheld programmers that can do this.
Old Jan 29, 2007 | 03:54 PM
Tig's Avatar
Tig
So is TM another form of traction control?
Thanks for the info Tarheelz, I appreciate it.
Old Jan 29, 2007 | 04:03 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
No, it is Torque Management, it manages the amount of torque the engine can apply to the transmission.
Traction controll is part of the ABS system i believe, a totally different concept
Old Jan 29, 2007 | 06:19 PM
Member82,817's Avatar
i thought that was controlled by the throttle body?
Old Jan 29, 2007 | 06:39 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Traction control sensors are near the wheel hubs. The detect when the wheels aren't spinning at the correct rate vs the rpm the engine is at. Tq Mng pulls timing to reduce the power the engine can make and therby reducing how much gets to the tranny. I think its all calculated in the computer. It calculates X times Y and figures it is making too much power and pulls timing until X times Y doesn't equal too much any more. Thats one technical description right thar! I say take it all out but, I'm on my 5th transmission.
Old Jan 29, 2007 | 08:00 PM
blown3qtr's Avatar
That's it in a nutshell. You can edit the allowed max torque, and the amount of torque management per gear. Torque management is applied when accelerating from low speed and when shifting. This is when the trans is most vulnerable.
my technical description: TM= no TM=
Old Jan 29, 2007 | 09:49 PM
shimp's Avatar
Is there a tutorial somewhere for working with the TM settings in HPTuners? I have looked at it a little and it looks confusing. Seems like there are 50 different settings for TM. There are probably only 1 or 2 tables that need to be modified to modify the TM settings but I couldn't tell which 1 or 2 those are....
I want firmer shifts and burnouts in my girlfriends 2002 Sierra. I can do nasty burnouts in my 2004, because as far as I know it does not have ANY TM because it is 5 speed!
Old Jan 29, 2007 | 11:11 PM
erronisme's Avatar
i think traction control will also decelarate the engine.... with mine on and playing in the latest ice storm if I punched it at any point while driving the engine drops the rpms almost as soon as the wheels start to spin.... but will allow them to slightly spin (probably the brakes pulsing, I would guess)
Wet tires, dry pavment and the TC turned off and I can get'em both to spin for a good long ways.
I guess this is the norm
Old Jan 30, 2007 | 07:37 AM
blown3qtr's Avatar
Try a search on the HPTuners website for "Torque Management". I'd look for you and post a link put I'm pretty lazy. Also in the tuning section of the help file there is a brief description of what tables to change when you put your vehicle into OLSD. There are better descriptions on the message board though. You don't want TM screwing w/ timing/fuel while tuning your ve or spark tables.
