Torque converter lockup
Old Jul 31, 2013 | 03:45 AM
  #21
subeone's Avatar
How to: understand your shift tables/towhaul and fix your speedometer with HPTUNERS
That is a basic write up I did on transmission tables w hptuners, use it.
Old Jul 31, 2013 | 02:50 PM
  #22
03 BLKTAHOE's Avatar
6.0 test run.hpl
NP 6.0.hpt
IS this what you guys need?
Old Jul 31, 2013 | 02:54 PM
  #23
subeone's Avatar
yes the NP file is the one we needed.
Old Jul 31, 2013 | 03:11 PM
  #24
Hey bud Ive been looking at your link thanks. In the torque converter lock up section under Auto Tcc I clink on the performace tab right? When you say max out 2nd and 3rd you mean change them all to 100?
  #25
subeone's Avatar
try these settings.
File Type: hpt
Old Jul 31, 2013 | 03:37 PM
  #26
try these settings.
Thanks I'll give it a try!
Old Jul 31, 2013 | 06:18 PM
  #27
Man unfortunately it didn't work, man I dont what to take the converter out but this thing sucks.
Old Jul 31, 2013 | 07:19 PM
  #28
AKlowriderZ71's Avatar
11 Second Hall Moniter
Change your minimum throttle release tables to match these. Lemme know.
Old Jul 31, 2013 | 08:06 PM
  #29
I made the changes and its still doing it. If I drive I, itt seems to go and then converter unlocks or locks not sure and I cant drive at high way speeds motor just revs. I have to slow down tell I believe tell it gets back it gets back first gear.
Old Jul 31, 2013 | 08:14 PM
  #30
That almost sounds like your transmission is slipping, not a converter lock/unlock issue. Have you checked your fluid? Pulled the pan? What does it look like?
