torque app and boost
Old May 6, 2013 | 02:03 PM
Bagman's Avatar
Default torque app and boost
Been trying to log some boost readings with the Torque App. I have a 5.3 with Vortech supercharger, speed density tune, 2 bar map etc. If I log boost, the vacuum is 100% correct but when I go into boost it stops at 0.5 psi. I have also tried logging intake manifold pressure and it maxes out at 105kpa. Is there a special PID I need to install etc? I am running 10lbs of boost according to my boost gauge, I would prefer to be able to log it for some different driving conditions etc. Any help or suggestions would be appreciated.
Old May 6, 2013 | 08:00 PM
Gadgetized's Avatar
Under
Settings
OBD2 adapter settings
Boost calculation method
Do you have MAP selected?
Old May 6, 2013 | 10:41 PM
Bagman's Avatar
I sure do. I havent tried any of the other settings since i dont have a maf etc. I really thought the infake manifold pressure would read correctly and i would just have to convert it, but no such luck. Hopefully someone can figure this out because it is kickin my butt.
Old May 6, 2013 | 11:50 PM
Atomic's Avatar
I have a gauge for that
If you have it tuned with HPT, its not the typical MAP sensor you need to log, its the custom 2 bar map in the PID list.
Old May 7, 2013 | 06:32 AM
Bagman's Avatar
Yes i am tuned with hpt. I dont seem to have the custom PID in my list though. The only 2 i have are boost and intake man pressure.
FlowmasterMufflers
Aug 17, 2015 04:44 PM
GreyChevy
Jul 7, 2015 08:57 PM
