Timing at launch?
Old Sep 30, 2009 | 01:11 PM
BlackGMC's Avatar
Resident Retard
Default Timing at launch?
I was just wondering what everyone else does meaning the moment you launch is your timing high or low? Do you ramp up or ramp down??? I am thinking i might gain some 60ft by playing around with the timing at launch....
For example, currently at the track I stall up to ~2k and flash it from there, it usually hits around ~3200 and about 21-22* of timing and ramps up to ~27-28*... I am wondering on the initial hit if the timing should be higher since the the load is less (grams/cyl)... I can only really test it at the track cause if i try to do it on the street i just flame the tires...
So in short what is your timing at launch and RPM?????
Old Sep 30, 2009 | 01:44 PM
dlt76028's Avatar
good question.
Old Sep 30, 2009 | 02:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Why wouldn't your timing in those cells already be at or near maximum gain anyway?
Old Sep 30, 2009 | 02:14 PM
BlackGMC's Avatar
Resident Retard
Cause i do my own tuning, so they are my spark tables... I really need to get on a load bearing dyno to dial in my Spark table, Justin set me up with a guy to show me how it is done, but I just don't have the money for his time and the dyno time....
Old Sep 30, 2009 | 02:24 PM
trever1t's Avatar
Yeah, understand. I was fine until it came to the timing tables, I can't see how anyone can get partial throttle timing down on the street. I had it pretty close but definately the dyno is the way to work timing by maintaining consistant load (variable at that) across the entire rpm.
Old Sep 30, 2009 | 02:30 PM
BlackGMC's Avatar
Resident Retard
Ya I worked on the PT timing, it is more by feel, no exact science. But my little Terd-mobile scoots pretty good now, I am just fine tuning the timing at the track, even there it is rather difficult
pittman
Jan 19, 2016 07:06 AM
Cammed4ever
Sep 8, 2015 06:52 PM
1bad2k
Aug 18, 2015 09:50 PM
fastjweb
Aug 15, 2015 10:47 AM
121
Jul 16, 2015 12:18 AM
