Throtte Body Gremlins...!~@#$%^&*
Old Sep 9, 2011 | 09:59 PM
  #101
DrX's Avatar
DrX
Originally Posted by CalEditor@PCMCalibrators
My bad, but you have a GMIN correct?
No .....
Old Sep 10, 2011 | 08:37 PM
  #102
2005 Silverado's Avatar
SPAM HUNTER
I had the same 1518 code...mine was a broke ground on the passenger rear block. Funny thing is i pulled on that wire first a week ago
Old Sep 11, 2011 | 10:11 AM
  #103
EVILGMC's Avatar
I relocated that ground to the firewall lug.
Old Sep 12, 2011 | 10:10 AM
  #104
CalEditor@PCMCalibrators's Avatar
FormerVendor
I have something for you to try
Old Sep 14, 2011 | 11:23 AM
  #105
EVILGMC's Avatar
Have not had time to work on it this week. Doing work on the house and waiting on some parts from the truck.
Old Sep 15, 2011 | 01:14 PM
  #106
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by EVILGMC
an 87mm 3 bolt TB wont bolt up to my blower anyway.
I'm not sure if it would help you at all but my 2300 came with a 3 bolt TB adapter plate kit. I was having TB issues like you were with my LS2 90mm TB and harness, so I bolted my OEM 3 bolt TB (2002 Tahoe, maybe 78mm?) on the 2300 and it worked.
The LS2 TB with adapter wiring haness would open 100% when the key went on (engine off) stay open for 10 seconds or so and then shut. I could then hit the gas pedal and it responded perfectly. As soon as I started the engine, the TB would not respond and it would set codes. I gave up.
Old Sep 17, 2011 | 07:17 PM
  #107
EVILGMC's Avatar
I GIVE UP
Old Sep 17, 2011 | 09:02 PM
  #108
lady3bglover's Avatar
Ok.. I've read a few pages of this thread and I was wondering if the two sensors that are on the driver side of the TB have been checked?
If I'm wrong, sorry I mentioned it.
Lisa
Old Sep 17, 2011 | 09:20 PM
  #109
chpspecial's Avatar
I GIVE UP
Have you tried a new PCM, but instead of flashing it with HPT, try EFILive... or at least a different running version of HPT. I know a while back that HPT had some issues with burning up TAC modules, and what not in a beta release.
Old Sep 17, 2011 | 10:02 PM
  #110
DrX's Avatar
DrX
The sensors are built into the throttle body on the drive by wire TBs. He has tried several different throttle bodies and several X-Links.
Problems with the wiring, OS or PCM are possibilities.
