In tank electrical connection
Old Feb 5, 2023 | 08:35 PM
Bgbldodge's Avatar
Default In tank electrical connection
Need to tie in my fuel pump into the harness that goes into the sending unit. How do yall do that for in tank and protect the connections? Fuel resistant heat shrink? Im thinking of trying to unpin the wires in the gray connector on top and connecting the fuel pump that way.
Old Feb 5, 2023 | 11:36 PM
RDF1's Avatar
DuNnO
5 Year Member
heat shrink butt connectors. Stagger them by an inch or 2 just to be safe.
Old Feb 6, 2023 | 12:43 AM
Bgbldodge's Avatar
Really? Seems to simple.
Old Feb 6, 2023 | 10:33 AM
RDF1's Avatar
DuNnO
5 Year Member
Yep. I've done more than a couple in the last few years. Stagger them so incase of a insulation failure you don't have a smoke show inside the fuel tank
Old Feb 6, 2023 | 11:32 AM
Atomic's Avatar
I have a gauge for that
Gasoline is an excellent electrical insulator. You can have exposed terminals in the tank and be fine, just dont let them touch.
Old Feb 6, 2023 | 02:50 PM
Bgbldodge's Avatar
That's just wild to me. All the crap we do to keep the tank as far away from ignition sources as possible and yet leaving bare wires with voltage just sit in it is perfectly normal.
Old Feb 6, 2023 | 03:08 PM
Atomic's Avatar
Yea gasoline and air is very bad, but submerged in gasoline is fine.
Old Feb 6, 2023 | 05:22 PM
shakenfake's Avatar
Shlumpt
5 Year Member
I mean it is the vapor that sparks up not so much the liquid.
Old Feb 7, 2023 | 08:14 AM
MikeGyver's Avatar
There's barely any oxygen in the space above the gasoline fuel tank, it is mostly fuel vapor. You would have to blow air in with your blow gun to get enough oxygen to support combustion.
On a side note, the reason that such thin wires are in the fuel bucket is because the ampacity of the wire is greatly increased by the cooling from the fuel. When you look into wire capacity, the charts usually are for so many wires in conduit. A single wire free in the air has a higher rating than a bundle of wires in a conduit, and wires submerged in coolant are the highest.
Old Feb 7, 2023 | 08:15 AM
MikeGyver's Avatar
There, you are smarter now.
