Speed density
Old Jun 16, 2006 | 08:25 PM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by vanillagorilla
Really? So do you use the Boost Enrich table at all? How does it all work with your LTrims? Do you even have to worry about them if you're not using the MAF?
I haven't turned my trims back on yet to offer any of my opinions with those questions, but I'd like to take a wack at the not using PE thing.
I certainly can see why you would choose to not use it. But I have been experimenting with the pe/be thing and I think it is very helpful. There is plenty of times that I can be in pe and not be. I just simply don't have boost yet, but I have my pe on at 93kpa. so there is some time there before 105kpa I am enjoying the "leaner" scenario because the "richer" scenario isn't needed yet. And as you know, that could be over a sorta wide RPM spectrum. Just completely experimental for me, I have no idea if it is more powerful that way. But I am not defending me keeping the pe, I am defending the way I drive, I at 45% to 65% tps ALOT and border the boost line.
WOT, yeh...no pe.
Originally Posted by EC_Tune on HPT Forum
PE & BE work in tandem. If you exceed the values to enter PE, you are in PE. The KPA to enter BE is just that, an enable point. I set it to 105 since the table starts at 100.
I just set the PE to something reasonable and run up the BE values from there. As you add manifold pressure, you need a slightly richer mixture-to a point.
An advantage of BE is that you can richen/lean out a particular MAP line to suit your vehicle. The biggest advantage is that you can adjust your PE (BE) value to suit the manifold pressure.
If you are 1 bar + MAF you can only achieve the PE value which may not be optimal if you are not at full boost.
And the final benefit of a 2bar table is that you can go into the VE and richen or lean a particular area to suit the engines needs.
As with EC's description you can see the oppurtunity to still ignore pe, but I also see how it could be utilized, at least in my driving style. Obviously turbo knows this, and being a really awesome tuner, I'd imagine he can tune around many things in his tune all day long. I just wanted to offer another side. LOL I seem to do that alot lately eh? Thread topic though...I am not going back to the maf once my ve is locked in.
Old Jun 16, 2006 | 09:46 PM
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by TurboBerserker
What kind of tuning software are you going to use? I really recommend EFI Live for this -- it makes it so easy to get your VE table.
Actually Allen is going to tune it for me. he's also going with a SD tune for his AValanche And is going to help me get mine to an SD. I guess i'll have to get a 2 bar map somewhere ?
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
BlownHD
Oct 3, 2015 12:24 PM
Lthompson
Oct 2, 2015 12:45 AM
Rockrz
Sep 29, 2015 09:07 AM
