Should my tune be changed?
Mods are in my sig... Had a mail order tune done by a sponsor and have no complaints at all. This is my first go around with a cam and custom tune... My question is when I first crank my truck up when it's in open loop it seems like it has more *** and throttle response than after it warms up. Yes I know it's not good to do full throttle runs when it's cold and I haven't done that just at part throttle it seems more responsive... I'm not complaining about the tune at all they did a great job no drivability issues at all just was wondering about this..
I don't have any tuning software. Just got a mail order one... Guess I need a live tune? I don't want anyone to get the wrong idea... I'm very happy with my tune... I understand only so much can be done with a mail order tune... I was just wondering what the difference I feel can be caused from. Thanks for the reply. I have never tuned anything but I'm very mechanically inclined and learn fast... How hard is it to learn to tune these trucks? Should I get hp tuners and start learning? We are starting to do a lot if ls swaps into older muscle cars at work... I'd like to get to learn the tuning side so we don't have to outsource that side of it.
Either way, my assumption with your file is that you need more timing/fuel.
9 Second Club
Yes, a mail order tune can only be so good - no substitute for a live tune with a wideband. There are fuel and spark differences from cold open loop to hot closed loop, so it is anyone's guess which is off. One thing you need to be sure of is that you don't have any exhaust leaks - that can cause un-needed fuel to be added when you go into closed loop, which can cause an overly rich condition during part-throttle...
Learning to tune is hard for some, not so hard for others... I think the best is if you have someone experienced nearby you that can give you some pointers - but some people do well learning from online or books...
Sounds right about needing more fuel/timing... I'm sure it was set up as a safe tune... What all do I need to get set up tuning? I've looked into it and there is JUST the software then they offer sensors n such...
Speaking of exhaust leaks... I did have trouble getting my off road y pipe to seal but i think its good now... But I know I don't have any leaks where the headers bolt to the heads and the o2 sensor is at the collector before the y pipe so a leak in the y pipe shouldn't affect that right?
9 Second Club
You will need a wideband - I prefer a serial wideband because with EFILive, a serial connection eliminates any grounding issues that you see with an analog wideband connection. That is one reason I prefer EFILive to HPtuners (HPtuners doesn't have a serial input). There are other reasons as well, but most of them come down to preference, not capability.
9 Second Club
