shift points
Old 01-07-2009, 11:24 PM
53RUSSELL's Avatar
Default shift points
So i did my first dead stop pull on 8lb of boost. My question is why after i hit 5,000 rpm the boost starts dropping. My shift points are set at 6000. What should i lower them to??
File Type: efi
Old 01-07-2009, 11:47 PM
nonnieselman's Avatar
I dont see why the boost would drop.. the T70 should have enough breath for a good 10-12# on 5.3...
i have the base STS turbo.. 60mm and im shifting out at 5800ish cause it feels like it falls on its face after that.. but i think thats a exhaust housing restriction..
what Kpa are you seeing? i see 136 on your scan..
Old 01-08-2009, 12:03 AM
53RUSSELL's Avatar
I see all way up to 150kpa in 3rd gear than it start follow after 5200rpm to 45kpa.
Old 01-08-2009, 12:06 AM
it falls to 45kpa? Thats vacuum man.. 95-105kpa is atmospheric (key on, engine off reading).
almost sounds like you have a boost leak or something.. you have a BOV??
Old 01-08-2009, 12:14 AM
53RUSSELL's Avatar
I see all way up 150kpa and then fall to 145kpa.
Here i made up this graph so you can see what i'm talking about.
Where the rpm drops that the shift poits.
ok i DLed ur scan..
are you using a boost controller?
your boost is all over the place.. and it doesnt have but 13xkpa in first but it goes up to 145ish Kpa in 2nd and 3rd...
Seems like you have a boost controller acting up?
Old 01-08-2009, 12:16 AM
i see what your talking about now... nice graph!!
your boost is falling when your rpms are rising..
my first boost controller did that to me, now i have something rigged up and it works great.
Old 01-08-2009, 12:20 AM
53RUSSELL's Avatar
Yes I have boost controller it is a Hellman boost controller.
I'll take a look at to see what up with it.
Old 01-08-2009, 12:26 AM
i just looked at a few logs of mine... my Kpa dances around maybe -/+ 2-3kpa.. but nothing crazy like yours.. Take the BC off and go make a log.
the boost controller i have now works perfect.
Old 01-08-2009, 11:51 AM
High on diesel fumes
thunder550's Avatar
I think it's pretty normal for a manual boost controller to drop a little bit of boost up top. Mine still does that too. I've been playing with spring pressures in the wastegate, and it's reduced it a bit, but it still drops about 2-3 psi in the high RPM's. I'm just going to deal with it....not worth it to me to put in an electric boost controller to get it back.
Quick Reply: shift points
