Shift point v. fuel cutoff problems
Old Jun 3, 2007 | 09:11 PM
dc_justin's Avatar
Hello Dave
Originally Posted by 1SlowHoe
The 1-2 is set to 36mph the 2-3 is set to 67mph. I guess I need to lower those up a bit? That way the speed will be met before I reach the rpm I want to shift at? What has primary control, the speed or the rpm? I think its the rpm from what I've seen.
I have 4.10 gears and 32" tires.
Both conditions have to be met before. In fact, three conditions have to be met. If you have a higher shift MPH in the 100% throttle cell of the part throttle shift table, it will depend on that as well.
Old Jun 3, 2007 | 09:50 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Will setting the WOT tables MPH to zero work? (table D910....etc)
Then it will only be looking for the rpm I have set to be met correct? So set D940...etc to 6100 and the fuel cutoff at 6500?
Old Jun 3, 2007 | 11:08 PM
ridnlow's Avatar
that looks right..
Old Jun 4, 2007 | 06:44 AM
dewmanshu's Avatar
Moderately Differentiated
yes
Old Jun 4, 2007 | 08:25 AM
dc_justin's Avatar
Hello Dave
Check your 100% Part throttle shift point as well.
Old Jun 4, 2007 | 02:11 PM
gmforlife's Avatar
I had a similar problem back in the day, i had set my mph too high of a speed, and it would hit the limiter before it shifted, so i just lowered my mph and it works just fine.
Old Jun 4, 2007 | 05:06 PM
litreddevil's Avatar
Banned
i will look to see if i am zeroed out on thr mph
Old Jun 4, 2007 | 05:34 PM
1SlowHoe's Avatar
What table is that?
Old Jun 4, 2007 | 05:57 PM
zippy's Avatar
Something to keep in mind here is that if you have an eletronic throttle body (such as an 03' or newer), you will have 2 rev limiters to set. You can raise one and still hit the other. If you have a pre-03' truck with traction control you'll also have an etc.
Old Jun 4, 2007 | 06:00 PM
1SlowHoe's Avatar
I do have all of the above. 2002 traction control electric TB. What tables should I be looking at?
