searched with no help
Old Aug 4, 2011 | 11:52 PM
Trezent's Avatar
Default searched with no help
i have searched long and hard but came up with zip.
Does anyone know if adding a trans temp gauge to the stock 04 cluster is as simple as putting in a stepper motor the overlay and a needle?
I am replacing 2 bad steppers anyways so if it is i can put in a trans temp as well.
If anyone could help that would be great.
Old Aug 5, 2011 | 12:00 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
No, it's not that simple.
Old Aug 5, 2011 | 12:08 AM
Trezent's Avatar
figured that life is not that easy.
so it needs to be programmed with the correct specifications for the trans temp in Tech II huh?
Old Aug 5, 2011 | 12:20 AM
No, the printed circuit on the back is different as well. By the time you "built" your own, you could've just bought one, had a warranty, and be done with it.
They just plug in & work, no programming needed.
Old Aug 5, 2011 | 12:42 AM
Trezent's Avatar
yeah i know that but the milage is wrong and getting them changed is a pain in the ****
the real reason i was asking is i got a deal on a escalade bezel and overlay for like 40 bucks so i was gonna just rock it. i may just place a needle in it and leave it be for now i have the trans temp in my Aeroforce gauge.
oh well well see how it works out.
Old Aug 5, 2011 | 12:47 AM
black04's Avatar
There is a spot on the stock cluster for the extra stepper motor. It works on some trucks just by adding it but not on others. but if you add it then the cluster can be programmed to turn it on. I tried it on my stock cluster and it didnt work without programming the cluster but i know others have had luck.
Old Aug 5, 2011 | 12:51 AM
Trezent's Avatar
AHHH so there is a glimmer of hope!!!
i hope i am the lucky one cause this would be an awesome cheap update. i may even go led if it works.
just put that in there because it makes me laugh every time!!
Old Aug 5, 2011 | 12:54 AM
black04's Avatar
I believe i read about it on an avalanche forum. I think i have it bookmarked on my work computer so i will post the link tomorrow.
Old Aug 5, 2011 | 01:01 AM
Trezent's Avatar
cool man thanks. that is exactly what i was looking for been searching my butt off my head is hurting i need a beer and a smoke.
Old Aug 5, 2011 | 01:03 AM
black04's Avatar
I FOUND IT!!! The stepper motor for that tranny temp guage...and others!!!!
Heres one thread that says pretty much what i told you. Some work and some need to be programmed with tech II.
