SDtune?
Old Oct 16, 2009 | 07:20 PM
blown 04's Avatar
Default SDtune?
when setting a tune up for 2bar sd do you change your high rpm disable higher then 4000 ?
Old Oct 16, 2009 | 07:30 PM
Wheatley's Avatar
Truck Sponsor
With HPTuners
Set your MAF fail high to 0.
You must throw a P0103 code in order to run SD.
you can set P0103 to no MIL so the light wont bug you,but do not set to no error reported!!
Old Oct 16, 2009 | 07:31 PM
BlackGMC's Avatar
Resident Retard
hmmmm, what are you talking about, are you refering to the rpm for direct airflow calculation (meaning when the MAF takes complete control for the airlfow calc)?
IMO for 2bar sd, if you have not allready done it you need to increase your MAP scaler to accomodate the 2bar sensor, then you fail the MAF....
Old Oct 16, 2009 | 07:32 PM
BlackGMC's Avatar
Resident Retard
damnit you beat me to it charlie...
Old Oct 16, 2009 | 07:36 PM
Wheatley's Avatar
Truck Sponsor
LOL Sorry about that Corey.I just saw there were no reviews and figured I would throw this in.LOL
Old Oct 16, 2009 | 09:17 PM
blown 04's Avatar
I guess what im asking is since now i will only use my ve table do i have to set the the high rpm disable to a higher rpm, under [engine] [airflow] [dynamic airflow] ? Stock was 4000 and i thought that was when maf took over but now im just ve i would want that higher?
Old Oct 16, 2009 | 11:05 PM
JonCR96Z's Avatar
If you're successfully failing or removing the MAF it doesn't matter about the high rpm disable, but you can just max it out for piece of mind.
whoopassracer
Nov 4, 2007 06:33 PM
whoopassracer
Nov 1, 2007 06:13 PM
whoopassracer
Oct 28, 2007 09:20 PM
whoopassracer
Oct 26, 2007 06:25 PM
