Running Lean!!!!!
Old Nov 24, 2007 | 08:51 PM
closet red neck's Avatar
Originally Posted by v8
You need to go see allen and let him show you a few things, and let him tune it again in person. Good luck.
Um, I'll call you on that one.
James
Old Nov 24, 2007 | 08:52 PM
v8
17,16,15,14,13,12,11 Drvr
James
I called you but you did'nt answer ahhaaha
Old Nov 24, 2007 | 08:54 PM
v8
That's what I was thinking too. But if you get the timing down to 29, doesn't the truck still take the same amount of fuel for the air coming into the engine??? If youput 29* total into it and lean it out, you're doing the same thing @ say 38* and leaning it out. It's just on a lower level. An engine detonating with 29* is easier on the bottomend then when it's detonating with 38*. Tomorrow I'm going to put in a new tune with 29* total and start adding fuel.
Please, I'm not trying to argue with anyone, I'm trying to understand this computer tung stuff.
James
You might get better answers on hptuners forums, call me and we can talk alittle. lateroooo
Originally Posted by Rhino79
Ditto, you may have a fuel problem, but thats way too much timing. I bet its not making any extra power past 28-29*.
My second tune from, Allen he had 36* total.......Then when winter hit, the truck would detonate and my fix was to put colder plugs in. Sometimes it still would det., but then I had him take some out.
James
Old Nov 24, 2007 | 09:58 PM
ap2002's Avatar
how do you determine?? cause of his setup??compression?? my nitrous tune has 26/27* and my motor tune is at 33.5*? and just by the SOTP feel it felt alot better? we had it up to 37* at one point while tuning it and it would take it without any issues, but it seem to scare us having that high so we cut it back..
not arguing with you but I am just wanting to learn more about all this asswell?
James, replacing your stock fuel pump is always a good mod anyway,
Old Nov 25, 2007 | 04:19 AM
Rhino79's Avatar
9 Second Club
I have tuned several setups, and there is a point where you may not be getting KR, but its just additional heat running timing that high. I have seen the same things on some trucks too, but more timing without detination doesn't always mean more power. Generally the more efficient the cylinder head the less timing you will need to run. Of course every setup is different. One example: I have a friend with a 2001 WS6, full bolt-ons, auto, stock stall dynoed 345 RWHP and the car didn't like over 24-26* of timing. I have done some stalled setups that were similar and they liked a few more degrees. I have done some cammed setups that will take more timing, Tan327's old 5.3 with the 226/226 was at 31* without KR before we backed it down to 29*. You really need to put it on a dyno to find exactly what is makes its most power with. 33* and 36* figures sound very high to me though.
What cc chambers are the edelbrocks, and what is your CR? Also take into account that the knock sensors may have been desensitized, so it may be less prone to show KR, even if it was occuring.
Old Nov 25, 2007 | 10:01 AM
ap2002's Avatar
now it makes alittle bit more sense, but it is true if you put it on a dyno you'll see there if there is a difference form certain * to the other *.....
Old Nov 25, 2007 | 10:08 AM
dirt track racer 81's Avatar
on the dyno i never seen a gain past 28 degrees
Old Nov 25, 2007 | 10:09 AM
also its you pump thats being maxed out
Old Nov 25, 2007 | 10:11 AM
Rhino79's Avatar
9 Second Club
True, and I will admit I do way more LS1's than I do 5.3's, but my findings tell me that they are very similar as far as spark advance, maybe get away with a little more on the trucks because of the lower compression generally speaking.
