-   Tuning, Diagnostics, Electronics, and Wiring (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/)
-   -   Run your 4L80E swap on a 4L60e tune with no segment swap (https://www.performancetrucks.net/forums/tuning-diagnostics-electronics-wiring-161/run-your-4l80e-swap-4l60e-tune-no-segment-swap-486918/)
black04 Aug 10, 2011 10:17 PM
If you want to know how to do it you can buy the instructions from this guy
PerformanceTrucks.net Forums - View Profile: slow67
A lot of you guys complain about the lockup on the 4L80e that is built into the 4L80e tune. With this small modification you can run your 4L80e transmission on your 4L60e tune without doing a segment swap. You also do NOT need the extra iss wiring pigtail for the front of the transmission.
4L80 tune no longer *required* - LS1TECH
Mangled03gmc Aug 10, 2011 10:34 PM
GREAT INFO.. Thanks :cheers: STICKY MATERIAL
GMCtrk Aug 10, 2011 10:57 PM
Cool info. If I ever install a high stall again I will be doing this.
aaronmc Aug 11, 2011 12:02 AM
I agree, good info.
marlboroman71818 Aug 11, 2011 05:20 AM
Originally Posted by Jake's Performance (Post 4751190)
The problem is you've stolen someone elses intellectual property, AND their instructions verbatim.
actually, if it was given to the public before having a change of heart like said and as long as it is the same information that was given, then there should be no problem
toddhowudoing Aug 11, 2011 06:38 AM
480le
what is PWM?
black04 Aug 11, 2011 11:24 AM
Yes here is the original thread. Credit goes to slow67 for the writeup.
Originally Posted by toddhowudoing (Post 4751225)
what is PWM?
Pulse width modulation.
Atomic Aug 11, 2011 11:34 AM
Hell yea! Going to try this very soon! swingit
phasemaster1 Aug 11, 2011 03:49 PM
Please explain keeping pwm and deleting pwm's effect.
black04 Aug 11, 2011 03:54 PM
PWM slows the converter lockup so it feels softer but it causes more wear on the clutches. If you google it there a lots of people that want to delete it but I dont think its as easy to delete on a 4L60e.
