replaced steering column/ engine won't start?
Old Aug 17, 2006 | 08:46 PM
wabmorgan's Avatar
Default replaced steering column/ engine won't start?
Friend of mine has a 2002 Silverado. It was recently involved in a frontal collision.
They had to replace the steering column. Now the engine will crack but it won't start.
Is the key somehow encoded??? And if so, would it cause this problem???
Lastly, how to correct???
Old Aug 17, 2006 | 08:59 PM
TXsilverado's Avatar
do any of the keys have a little black chip on them? if not try a crank sensor relearn
Old Aug 18, 2006 | 05:16 PM
Grumpy5.3's Avatar
tell him to relearn his security, this has to be done by the dealer!!!
Old Aug 19, 2006 | 12:53 PM
dc_justin's Avatar
Hello Dave
Agree with Grumpy, but it doesn't need to be done at the dealer. Takes about 45 minutes to do it.
Attempt to start, when it fails, leave the key in the run position for 11-12 minutes (til the security light goes off).
Turn off for 30-45 seconds.
Repeat first step.
On the 4th attempt of this process, it should fire up.
Justin
Old Aug 19, 2006 | 11:51 PM
Grumpy5.3's Avatar
Repeat first step.
Justin
I didnt think it would work like that on an 02, sorry... my bad
guess I am just used to having a tech 2 around...
Old Aug 20, 2006 | 12:38 AM
dc_justin's Avatar
Hello Dave
Wish I had easy access to a Tech 2.
Old Aug 20, 2006 | 10:00 AM
Grumpy5.3's Avatar
working at the stealership has its perks, I guess?!?!?
Old Aug 21, 2006 | 02:09 AM
wabmorgan's Avatar
Well.... you guys hit the nail on the head. I called a friend of my dad's that works at a dealer, he came up with the same answer as you guys. They fixed it!!!
Old Aug 8, 2016 | 04:22 PM
Jenny Pearson's Avatar
Registered User
Default Help me please
I have gmc envoy replaced steering colomn now won't start was doing the 4 times till security light went off but the 3rd time sec light didn't come on but doesn't crank any suggestions?
Old Feb 10, 2017 | 03:29 PM
5starsparklingpools's Avatar
Registered User
Default Resetting passlock
What if the security light doesn't turn off it stays on?
