REALLY annoyed.....
Just venting,
During my Whipple install, I paid $800 (as part of the install) for a tune. Little did I know, it was half ***'d from the get go.
1. No 2 bar OS (tuned with 1bar, MAF only it looks like)
2. VE table wasn't tuned properly
3. Truck would go pig rich to 10.0 (AFR gauge only reads to 10.0) during a part throttle to full throttle transition.
So, when I put the 2bar OS on it, it wouldn't idle. It would crank, then die immediately.
Through MANY tune revisions (17 now), the VE table is getting settled in and it's running 110% better than when I picked it up from the install.
Here is what the VE table looks like now:
84 80 80 86 90 93 94 93 94 91 92 87 80 81 81 81 81 81 81 81
83 74 78 80 85 89 90 90 94 93 92 89 88 90 91 92 93 94 94 94
80 72 75 80 83 87 88 88 90 90 88 89 89 93 94 95 96 97 98 98
81 74 77 81 83 85 86 87 87 89 89 86 90 92 93 94 95 96 97 98
87 81 82 82 83 84 79 80 82 89 88 87 90 92 93 94 95 96 97 98
90 86 87 83 83 85 84 82 82 93 93 91 90 92 93 93 93 94 95 96
94 91 92 95 97 95 91 85 86 96 96 89 90 92 93 92 92 92 93 93
96 96 97 108 112 106 98 89 91 99 99 92 94 93 93 92 92 93 93 93
96 98 101 109 119 122 114 101 96 102 103 94 96 93 93 93 93 94 94 94
97 99 102 116 126 137 129 113 109 105 106 97 96 96 97 98 97 97 98 98
97 101 106 121 132 143 148 132 116 105 106 105 103 102 101 100 101 101 101 101
97 103 110 126 138 147 162 140 134 121 119 115 113 111 108 105 105 105 105 105
97 104 112 129 142 151 156 147 141 131 130 127 121 114 110 106 105 105 105 106
98 104 114 131 145 156 162 155 147 139 138 133 126 119 113 109 108 108 109 109
99 105 115 134 149 161 168 161 154 145 143 138 131 123 118 113 112 112 112 113
97 105 117 137 153 167 174 166 159 150 148 143 135 128 122 117 116 116 116 116
95 105 120 141 158 172 180 172 164 155 153 147 139 132 126 121 120 120 120 120
93 106 122 144 163 177 185 178 170 160 158 152 144 136 130 124 124 124 124 124
93 108 123 147 166 181 188 183 174 166 162 156 148 140 134 129 128 128 128 128
It's not perfect but we're still tuning it.
Thanks to Atomic for helping me with it. He's been a great help.
We talked about it a lot in email, and I haven't been shy about admitting publicly its one of the big problems when shops get large; they don't have the time or interest to really dial in a setup. They have the ability absolutely, but most guys aren't going to pay for the hours of tuning needed to really get a setup dialed in. A couple passes on the MAF with a wideband and out the door you go. Pretty sure your VE table was never touched.
What half of those iterations were related to is figuring out that what they said was a "2.5bar map" is actually a 2bar, which is a very important detail. The "house brand" injectors also worry me a bit, but they seem to be ok thus far.
I would be ashamed if I charged someone $800 to only do a couple passes on the MAF table and remove TM.
VE table values are somewhat arbitrary and depend heavily on what is used for engine size and injector size. Non-referenced FPR setups always have increasing values in boost areas since you are basically having to trick the injectors into adding more fuel. On a referenced FPR setup, the values are nearly constant going straight down a particular column. Not a bad thing, just worth point out.
I'm dealing with the same.. From time to time depending on the temp outside running good or running ruff! New tuner needed!
