Random misfire help
Old Nov 21, 2012 | 09:05 PM
  #21
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by BetMinesFaster
I agree 100% with your reasoning. The reason I vote for a CKP variation relearn is, its free, and if a 6.0 has 1 or 2 cylinders missing and a flashing MIL it will be blaitently obvious in the power dept. He said the truck is running fine. Odds are it needs a relearn.
With an unlearned CKP variation the misfire can float and change cylinders as well. Seen it happen numerous times.
You seldom see coils bad on these trucks. Very seldom.
I would not be concerned about PID data on a sensor that looks way out of wack unless there is a code for that sensor/system. If the MAP signal was way off it would have set a MIL and a code for that.
Ryan
I don't Blame you one bit for saying to try it first. If the plugs and wires aren't sound you could potential chase the problem. I had a similar problems. The miss fire monitor would show 2 or 3 cylinders with an occasional miss. The miss would move after I preformed a relearn. New plugs then performing a relearn solved it. Basic maintenance never hurts.
I have never personally seen a coil go bad yet on one of theses trucks yet. I have seen Computers and wiring issues but never the coils them self's. The only time I have heard of issues with the coils is when guys mess with the Tuning parameters and burn them up.
Old Nov 21, 2012 | 09:10 PM
  #22
06murder's Avatar
If its 03 and up the fliter is in the tank....get fuel pressure gauge and see if it push the right amount. You could have an sticking injector also
Old Nov 21, 2012 | 09:40 PM
  #23
zeake's Avatar
Originally Posted by zeake
OK, I did the ckt variation relearn. that code has left gthe building. It has only been 7 miles though. P0446 came back immediately.
Thanks a ton for the info Betminesfaster
Thanks
Jake
Since some of you missed it. Lol
Old Nov 21, 2012 | 10:34 PM
  #24
1FastBrick's Avatar
P0446 Evap Vent System performance could be any thing.
Conditions for setting this code:
The ECU fails to detect a drop in the EVAP system vacuum over a calibrated number of seconds with the vent solenoid open.
First thing to check is the Gas cap. Make sure it seated properly. If the sealing ring around the cap is cracked or damaged, replace it.
Look at the freeze frame data from when it failed. Try and monitor the Fuel pressure sensor in the tank.
You should also be able to preform an evap system test with the Solus Pro.
Old Nov 22, 2012 | 07:18 AM
  #25
zeake's Avatar
More great information thanks. I may try to look at it later this afternoon. % hours of driving then I am done for the day. I have replaced the gas cap however. Along with the fuel pump.
Old Nov 24, 2012 | 09:39 AM
  #26
TexasGMC08's Avatar
Grab the Solus, amd perform a Crankshaft Variation Relearn
I promise that will solve it. It you have ran it for any period of time like that flush the transmission.
A misfire prohibits converter lockup which causes higher trans fluid temps. Hard on fluid. Its cheap maintenance.
Do the variation relearn and post your results, im confident it will fix your problem.
good luck!
Ryan
Hey Ryan!! what are you talking about on this thread??? I am having that issue where my contertor will not lock up... sometimes my light comes on... Like this am i let it warm up and light was flashing and now its not WTF!! .... My tranny temp gets up to 228...
Old Nov 25, 2012 | 07:44 PM
  #27
BetMinesFaster's Avatar
Down and out
Is this in the truck in your sig?
228 is smoking hot. You need to flush your trans asap, and stop driving it untill its fixed. If that trans went 228 the fluid is junk. Do not ignore it or put it off.
We had to loosen up the misfire counters with HP tuners on one of my 6.0's with a TSP 220R cam, Your running a 224 that im sure has a lope at idle. That will definately cause miss codes. My truck even running flawless would occasionally flash the mil and store some misfire codes at idle and cruising speed. Likely camshaft induced. No issues once my tuner buddy took care of it.
If you did a cam swap, use a good scan tool and complete a CKP variation relearn. If that relearn is not performed after some major mork like that, it could cause erronious misfire counting, flashing MIL, etc. If its counting misfires it will not lock the converter. If its still counting misfires with the relearn performed, contact your tuner about loosening up the misfire counters with HP tuners.
PM me if you have any questions.
Ryan
Old Sep 23, 2015 | 08:54 PM
  #28
zeake's Avatar
I never did figure this out. New plugs wires, throttle body, relearn all just the other day, cam position sensor, nothing makes it go away. It only shows up when the fuel is low and the misfire and evap leak large show up at the same time. The misfire only shows up at 0 mph on a scanner. You never feel it.
I'm really tired if the cel and wasting money hunting the issue. I'm up for suggestions.
All O2 Sensors have been replaced as well.
Dirty injectors seem like they would be felt at idle or acceleration?
Clean injectors?
Update the PCM at the dealership maybe?
Old Sep 23, 2015 | 09:03 PM
  #29
1FastBrick's Avatar
It Might need an update, but I doubt it.
More likely the charcoal canister or the Purge valve are the issue. Sounds like the Leak is leaning out the motor just enough for a random misfire.
What are your LTFT and STFT at the time of failure?
Old Sep 24, 2015 | 06:37 AM
  #30
zeake's Avatar
I don't know about the ltft or stft I don't have access to a scanner at the moment. It throws the code once the tank is low and right after cranking. I'll try to get a charcoal cannister and purgevalve and replace them. The truck is 4000 miles from 200k and it runs and drives great. I just cant stand the cel
