possible problem...E85 93 and water
Old Jan 22, 2012 | 10:55 PM
lukn4trbl355's Avatar
Default possible problem...E85 93 and water
whats goin on guys...i just filled up about an hr ago, drivin around i felt my truck start running a little rough and acted just how it did 2weeks ago when i filled up with bad gas...well now my question is can i run sea foam with E85? or will that mess something up? i know its alright with conventional fuels but ive never heard anything with it being used on e85...also i think i mightve fucked up the 20% mix of E85, due to the cold i wanted to fill my tank to full even though i was on half tank...after fighting with the retard at the counter i put a full 7 gallons in thinking i was almost empty...could this ratio mess my motor up? if so whatre my options? drain the tank?
thanks in advance
tj
Old Jan 23, 2012 | 12:45 PM
nobody has any idea??
Old Jan 23, 2012 | 02:54 PM
f4tal's Avatar
Don't go WOT... the MAF should compensate some for the fuel mixture while cruising. As far as the sea foam i don't know if its safe or not. I would imagine it would be okay but don't take my word for it.
Old Jan 23, 2012 | 03:14 PM
BlackGMC's Avatar
Resident Retard
How much e85 did you put in? Also looking at your sig, why did you put it in you have no motor mods?
Old Jan 23, 2012 | 04:56 PM
slow67's Avatar
Gingervitis Addict
E85Forum.com :: View topic - E85 and seafoam uses (some one may want to sticky )
Old Jan 23, 2012 | 05:30 PM
fatal def i think im gonna limp this tank like ya said, specially with how shitty its running...n blackgmc i filled up at half tank instead of almost dry,so there were probably 3.5 gallons of E85 in it, then from half tank up i added another 7 gallons and topped the rest off with 93, so its probably in the 28-30% range, as for ur 2nd questioni talked to justin at bbp, asking him about E85 tune next summer, he told me i could run 15-20% with having to retune. i figured id give it a try n wanted to experiment, suprisingly it runs a lot smoother than it ever has, call me crazy but it seems a little better also. as for no internals...thatll be changed soon...as for that link thanks man definitley has some good info in it
turbo6c3
Oct 5, 2015 06:11 PM
Tigger Welder
Oct 1, 2015 08:41 AM
Benloe
Sep 22, 2015 10:24 PM
jfuegner
Sep 22, 2015 12:30 PM
Shotguntommy
Sep 15, 2015 05:24 AM
