PID list
Actually using EFI. Wanting to log a 99 5.3, bolt ons, cam, and 42lb injectors. So just wanting to tune everything all around to getting it running its best. Trans is good to go i believe, so everything else is what i'm needing. Thanks
LS1TECH Sponsor
things like RPM, MPH, commanded afr, fuel trims(unless you have them turned off), iat, ect, spark advance, knock retard, knock learn factor(if you believe knock may be affecting what table timing is coming from), etc. Its really about what YOU find useful or what exactly you are looking to tune at a given time.
Where's the Beef?
Right. You use whatever PIDS you need to do what your wanting to do. There's different PIDS for different things you may be doing.
Do 1 thing at a time, If your tuning the ve table, click on HELP on the top right of your window and look at the tutorial, it tells you what PIDS you need to do that.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
Closer_2001
09-24-2015 09:15 PM
