pcm type
Ok now Im a bmw tech for a living an pretty much have a good handle on which cars have which operating systems and what pcm they have. Now I don't know the gm stuff at all, is there some where I can go to see what year trucks had what pcm? I think my truck is an e38 correct? Id like to know my facts. Also is there anywhere I can look at all the inputs and out puts of the pcm? I wanna see if there are any unused outputs I could use to control various accessories. There is the temp output for the fans to ground a relay but I would really love to control my fan speed by pulse width. Thanks for your help.
Alex
Alex
It is a 99+ LS1 style PCM.
http://www.chevyavalanchefanclub.com...c,45153.0.html
Here are some controller ID pics from the EFILive documentation.
From the service manual:
Powertrain Control Module (PCM) - C1 (Blue)
Connector Part Information
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
DK BLU/
WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data
DK BLU/
WHT
774
UART Serial Data
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL/BLK
1868
Low Reference
22
Not Used
23
BLK
470
Low Reference
24
Not Used
25
TAN
413
HO2S Low Signal
26
TAN
413
HO2S Low Signal
27
Not Used
28
TAN
413
HO2S Low Signal
29
TAN
413
HO2S Low Signal
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch/Cruise Control Release Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRY
48
CPP Switch Signal
36
BLK
1744
Fuel Injector 1 Control
37
YEL/BLK
846
Fuel Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
PPL
719
Low Reference
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
Not Used
46
GRY
474
5 Volt Reference
47
GRY
596
5 Volt Reference
48
GRY
597
5 Volt Reference
49 50
Not Used
51
DK BLU
496
Knock Sensor 1 Signal
52 53
Not Used
54
ORN/BLK
469
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
PCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
510
Low Reference
61
PNK/BLK
632
Low Reference
62-64
Not Used
65
PPL
1670
HO2S High Signal
66
PPL
1666
HO2S High Signal
67
Not Used
68
PPL/WHT
1668
HO2S High Signal
69
PPL/WHT
1665
HO2S High Signal
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/
WHT
878
Fuel Injector 8 Control
78-79
Not Used
80
ORN/BLK
510
Low Reference
Powertrain Control Module (PCM) - C2
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
WHT
2467
Unmanaged Torque Signal
BRN
418
TCC PWM Solenoid Valve Control
TAN
1465
Fuel Pump Relay Control - Secondary
Not Used
TAN/BLK
464
Delivered Torque Signal
RED/BLK
1228
PC Solenoid Valve High Control-Sol. A
RED
1676
EGR Valve Supply Voltage
LT BLU/WHT
1229
PC Solenoid Valve Low Control-Sol. A
DK GRN/
WHT
465
Fuel Pump Relay Control - Primary
WHT
121
Engine Speed Signal
11
DK BLU
604
A/C High Pressure Recirculation Switch Signal
12-14
DK GRN
1163
APP Sensor 3 Signal
BRN
25
Charge Indicator Control
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/
WHT
2523
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
AT ISS High Signal
23
DK BLU/
WHT
1231
AT ISS Low Signal
24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/
WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
Recirculation Door Control
34
DK GRN/
WHT
428
EVAP Canister Purge Solenoid Control
35-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
WHT
257
EGR Solenoid Control
42
Not Used
43
DK GRN/
WHT
459
A/C Compressor Clutch Relay Control
44
Not Used
45
WHT
1310
EVAP Canister Vent Solenoid Control
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
2-3 Shift Solenoid- Sol. B-Valve Control
48
LT GRN
1222
1-2 Shift Solenoid-Sol. A-Valve Control
49
YEL/BLK
1827
Vehicle Speed Signal
50
DK GRN/
WHT
817
51
YEL/BLK
1227
TFT Sensor Signal
52
GRY
23
Generator Field Duty Cycle Signal
53
DK BLU
2687
Transmission MIL Request Signal
54
PPL
1589
Fuel Level Sensor Signal - Primary
55
DK GRN
603
A/C Low Pressure Switch Signal
56
Not Used
57
BLK
552
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRY
773
Transmission Range Switch Signal C
63
PNK
1224
Transmission Fluid Pressure Switch Signal A
64
DK GRN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-71
Not Used
72
BLK/WHT
3122
HO2S Low Signal
73
DK BLU
1936
Fuel Level Sensor Signal - Secondary
74
LT GRN/WHT
3213
HO2S High Signal
75
RED/WHT
3222
HO2S High Signal
76-79
Not Used
80
LT GRN
3212
HO2S Low Signal
- 12191489
- 80-Way F Micro-Pack 100W Sealed (NAT)
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
LT GRN/BLK
1745
5-10
Not Used
11
LT BLU
1876
DK BLU/
WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
14
ORN/BLK
1061
UART Serial Data
DK BLU/
WHT
774
UART Serial Data
16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
Ignition 1 Voltage
20
ORN
440
21
YEL/BLK
1868
Low Reference
22
Not Used
23
BLK
470
Low Reference
24
Not Used
25
TAN
413
HO2S Low Signal
26
TAN
413
HO2S Low Signal
27
Not Used
28
TAN
413
HO2S Low Signal
29
TAN
413
HO2S Low Signal
30
LT GRN
1478
31
Not Used
32
BLK/WHT
771
33
PPL
420
34
WHT
776
35
GRY
48
CPP Switch Signal
36
BLK
1744
37
YEL/BLK
846
38
PNK/WHT
1101
39
Not Used
40
BLK/WHT
451
Ground
41
PPL
719
Low Reference
42
Not Used
43
RED/BLK
877
44
LT BLU/BLK
844
45
Not Used
46
GRY
474
5 Volt Reference
47
GRY
596
5 Volt Reference
48
GRY
597
5 Volt Reference
49 50
Not Used
51
DK BLU
496
52 53
Not Used
54
ORN/BLK
469
Low Reference
55
BRN
1456
56
Not Used
57
ORN
440
58
DK GRN
1049
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
510
Low Reference
61
PNK/BLK
632
Low Reference
62-64
Not Used
65
PPL
1670
HO2S High Signal
66
PPL
1666
HO2S High Signal
67
Not Used
68
PPL/WHT
1668
HO2S High Signal
69
PPL/WHT
1665
HO2S High Signal
70
BRN
1174
71
Not Used
72
YEL
772
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
76
BLK/WHT
845
77
DK BLU/
WHT
878
78-79
Not Used
80
ORN/BLK
510
Low Reference
- 12191488
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
WHT
2467
BRN
418
TAN
1465
Not Used
TAN/BLK
464
RED/BLK
1228
RED
1676
LT BLU/WHT
1229
DK GRN/
WHT
465
WHT
121
Engine Speed Signal
11
DK BLU
604
12-14
DK GRN
1163
APP Sensor 3 Signal
BRN
25
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/
WHT
2523
A/C Request Signal
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
AT ISS High Signal
23
DK BLU/
WHT
1231
AT ISS Low Signal
24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/
WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
34
DK GRN/
WHT
428
35-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
WHT
257
42
Not Used
43
DK GRN/
WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/
WHT
817
51
YEL/BLK
1227
TFT Sensor Signal
52
GRY
23
53
DK BLU
2687
54
PPL
1589
55
DK GRN
603
56
Not Used
57
BLK
552
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRY
773
63
PNK
1224
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-71
Not Used
72
BLK/WHT
3122
HO2S Low Signal
73
DK BLU
1936
74
LT GRN/WHT
3213
HO2S High Signal
75
RED/WHT
3222
HO2S High Signal
76-79
Not Used
80
LT GRN
3212
HO2S Low Signal
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Wrecker 426
Sep 30, 2015 09:39 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
