PCM Communication
Old Mar 27, 2011 | 07:38 PM
SnakeOiler's Avatar
Default PCM Communication
For some years now, I have not been to connect to the PCM on the truck - as far as writing or reading a tune.
Using my Autotap interface - can't connect
Using the LS1Edit interface - can't connect
Service Dept. Tech II - can't connect
Actron 9145 scanner - CAN connect. I can reset codes, look at live data, etc. No issues with the Actron.
The ALDL has four wires:
12+ : is good, power is there
ground: works
ground: works
serial bus: obviously works as I receive data to the Actron scanner.
Any input as to why these other devices cannot communicate?
Any advice on what else to troubleshoot?
Thanks.
Old Mar 27, 2011 | 07:52 PM
Atomic's Avatar
I have a gauge for that
check the cig liter fuse
Old Mar 28, 2011 | 11:05 PM
SnakeOiler's Avatar
I knew I forgot to list something, thanks for the reminder.
I also couldn't find a blown fuse anywhere. I checked every fuse in the truck.
Old Apr 3, 2011 | 10:03 PM
SnakeOiler's Avatar
Problem resolved.
I took a good look at the terminals. The serial bus terminal and one of the ground terminals looked flat. I removed them from the connector, pushed the tabs back up, and reinserted back into the connector.
Everything now works. Good connections on every terminal.
Wrecker 426
Sep 30, 2015 09:39 PM
Velocity1
Sep 22, 2015 01:32 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
