p401?
Old Nov 29, 2011 | 10:16 PM
getchusum99's Avatar
Default p401?
i keep getting reacurring codes on my ses, always same one, p401-egr insufficient flow. my egr is supposed to be deleted with the tune i have. is their a separate DPFE sensor somewhere on the motor or is it made into the egr? didnt see one
Old Nov 30, 2011 | 07:43 PM
bump........
Old Nov 30, 2011 | 07:46 PM
Suburbazine's Avatar
It's comparing pressure values in the MAP and throttle angle tables to known values for the EGR states. If the EGR table isn't matched to the MAP values then it will throw the code.
I couldn't tell you how to go about fixing it, I have the same issue with my EVAP system.
Old Dec 3, 2011 | 05:37 PM
could it be my map sensor
? also does it change any parameters in the pcm/tune when the p401 comes on?
