P0446??
Old Dec 13, 2005 | 08:51 PM
jchorner99's Avatar
Question P0446??
P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction.
showed up as a trouble code a pending code and a freeze code.
checked the gas cap, on tight.. o ring looks fine. any ideas?
Old Dec 13, 2005 | 09:44 PM
budhayes3's Avatar
PT's Slowest Truck
Make sure that all of the hoses to the charcoal canister, fuel tank, etc. are properly installed and fully seated, also make sure that none are bent or kinked...a few different things could give that code...bad EVAP vent valve, fuel tank pressure sensor, even a bad charcoal canister (sometimes they break down internally and the pieces clog up ports)
Old Dec 13, 2005 | 11:10 PM
jchorner99's Avatar
could this have anything to do with the fact that I just installed my Nelson tuned 02' PCM @ 50 miles ago?
Old Dec 14, 2005 | 09:28 PM
budhayes3's Avatar
PT's Slowest Truck
That shouldn't have anything to do with it, unless there was an internal PCM problem. Anything's possible, but I doubt that the new PCM is at fault. EVAP codes are pretty common with just about every manufacturer...I had a similar code on my wife's Matrix about 6 or so months ago, and was able to figure out that the charcoal cannister was flooded with fuel. I figured out that it was a result of a local gas station squeezing every last drop while trying to round up to the nearest dollar (New Jersey isn't self-serve). I cleared the code and have been lucky so far (knock on wood)
Old Dec 14, 2005 | 10:20 PM
jchorner99's Avatar
cool, thanks man. I appreciate it. I'm going to check it all out friday. I'll post with findings
Old Dec 17, 2005 | 10:51 PM
jchorner99's Avatar
code cleared it self on the drive home today.... I guess mabye it was over filled. Although I never top off.... good riddance........wtfe... thx man. i appreciate it.
Old Dec 18, 2005 | 03:05 PM
2000Redstep's Avatar
Had the same code with mine. The dealer cleaned the filler neck to tank connection, $45.00 labor.
Old Dec 18, 2005 | 09:53 PM
budhayes3's Avatar
PT's Slowest Truck
Cool deal, hope it stays "fixed"
Old Oct 17, 2007 | 10:08 AM
OneBadSSS's Avatar
Default Got a SES light the other day :(
So my SES light came on the other day despite the fact that the truck's running strong and so I took it to Auto Bone to have then pull the code and P0446 x 2 is what I got. Any idea what kind of damage to my wallet I can expect when I take it into the stealership if none of the obvious things (loose connections, kinked hoses, etc.) are the culprit?
Old Oct 18, 2007 | 09:23 PM
Shamrock84's Avatar
Registered User
hey I had the same deal P0446 comin up twice on 2002 tahoe. i gas cap but it came back, if i remember correctly it was a bad evap vent solenoid that was failed to open, 50 $ new at dealer, replaced it and it was all good
Relentless07Silv
Apr 11, 2015 10:55 PM
TX Tahoe Z71
Apr 17, 2014 10:43 PM
offroadrider12
Mar 28, 2013 05:44 AM
offroadrider12
Mar 30, 2012 10:41 AM
Kev SS
Mar 15, 2010 10:01 PM
