P0440, goes on and off???
Old May 31, 2006 | 12:00 PM
agreif's Avatar
Default P0440, goes on and off???
Only reason I'm posting this after reading the search results was because it actually went off on it's own and then came back on.
Not sure if it's a coincidence or not, but after getting the new transmission installed, 2 days later I get the SES light and get the above code. It is an Evap emission control system malfunction.
here's some of the info I got off the GM site: This DTC will detect a weak vacuum condition (large leak or restriction) in the EVAP. system.
I went and read and cleared the code on Tuesday. came back on Thursday. I drove 280 miles to PA on Friday and about 200 miles into it the light went away. Warm and hot all weekend, never showed up. Went through some rain and around that same time it popped back on. Not sure if the weather and new tranny have anything to do with it (tranny is a little high on fluid). Just curious how it went off all by itself after a while and then popped back on. Any ideas?
Andrew
Old May 31, 2006 | 12:09 PM
RoninsDenali's Avatar
Check that gas cap!
It might be time to get a new one.
Also, since the fuel/evap lines run next to the transmission (driver side) make sure there are no kinks or obvious problems first.
Old May 31, 2006 | 12:22 PM
KySilverado's Avatar
Originally Posted by RoninsDenali
Check that gas cap!
The evap can and lines run right beside the tranny on the drivers side. With a tranny swap very possible to have messed something up in the area.
Old May 31, 2006 | 09:36 PM
agreif's Avatar
Default Found it!
Got under there and think I found my problem. Plastic purge line out of the evap canister has a hole. Probably residual damage from the driveshaft explosion. Think I can put some silicone to cover that hole or you think I should replace that little plastic line? It doesn't see any serious pressure so I think the silicone would work.
Andrew
Old May 31, 2006 | 09:57 PM
I'd probably just replace the line especially with anything related to fuel. And it might be important depending on how **** your state is with Emission testing.
Old Jun 1, 2006 | 03:37 PM
budhayes3's Avatar
PT's Slowest Truck
Or you could cut the line and try clamping some fuel line or larger vacuum hose over it....
Old Jun 1, 2006 | 04:07 PM
TIM Z's Avatar
11 sec. Truck Mod
just caught this thread, my truck has set these codes lately also, ive had my trans out also and will be checking the hoses and gas cap. Great help here guys!!
kr1s
Feb 20, 2012 12:52 AM
agreif
Jun 27, 2006 07:32 PM
TG02Z71
Sep 12, 2005 06:18 PM
TG02Z71
Sep 12, 2005 11:26 AM
mjgjr72
Aug 4, 2005 08:39 PM
