P0341 camshaft sensor
I think you may need a new sensor. That code is for sensor performance. The sensor on my truck is at the back of the block on the passenger side and a real bugger to get to. Have you had it out? Disconnected any wires from the back of the block? Have you put in a cam recently? Perhaps it is not aligned properly. Just trying to through out some ideas. Maybe the sensors are on the front on the newer trucks.
if you've installed it on a ur truck, its normal for the GMT900s to come up with this sensor... It's either to do with the DOD, or the fact you changed out the 1-bolt cam gear in exchange from a 3-bolt cam gear...
The cam sensor for the new trucks are in the crank/cam gear cover. Maybe if you change that out for a LS2 one, it might help...
