P0327 Knock Sensor Low Voltage
Old Dec 13, 2005 | 05:31 PM
thunder550's Avatar
High on diesel fumes
Originally Posted by BlownChevy
If you pull the supercharge system, just make sure your intake gaskets are good, more than likely you will need to replaced them.
OK cool thanks...if the wires are fine I'm gonna have to decide whether I want to bother pulling the s/c or just be content clearing the code every day or so until I can get the new motor in. Hmmm.......
Old Dec 13, 2005 | 10:23 PM
Formulized94's Avatar
hell worst case, if you have acces to a quick tune. take it out of the code table.
Old Dec 15, 2005 | 06:27 PM
thunder550's Avatar
Just tested the resistance of both knock sensors, which I guess are supposed to be right around 100K ohms each. Rear was right on, front was only 55K, so I guess there's my problem. Should I go ahead and replace both of them when I pull the s/c? How long are intake manifold gaskets good for? I'm gonna be pulling the motor apart in a month or two anyway for the LQ9 and I don't want to replace them twice.
Will that hurt anything? Knock sensors will still operate normally?
Old Jan 17, 2006 | 05:51 PM
digital's Avatar
Does anyone have a picture of the location of the knock sensor wires on the intake manifold?
Thanks,
Old Jan 17, 2006 | 11:03 PM
thunder550's Avatar
There's a few different ones in the Radix install instructions
http://www.magnacharger.com/pdf/manu...SUV1999-02.pdf
lucas287
31
Jan 12, 2021 06:18 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
creekrat
Sep 10, 2015 12:59 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
