p0172
Old Oct 16, 2005 | 02:38 PM
Gmc²'s Avatar
Default p0172
Fuel Trim System Rich Bank 1 ... which would be your o2 sensors i beleive
someone told me this^^
any one know a solution? that is the only code im getting
Old Oct 17, 2005 | 07:05 AM
z7199's Avatar
I had that code once and took it to a friend at the Dealer and he said it was more than just a 02 sensor we didnt fix it but the next day or so it turned offf by itself
Old Oct 17, 2005 | 02:42 PM
Gmc²'s Avatar
mine comes on about once a tank of gas for a while now
Old Oct 17, 2005 | 11:12 PM
budhayes3's Avatar
PT's Slowest Truck
Could be the bank1 O2 sensor (driver's side front sensor B1S1), or you may have a rich condition on that bank. Possibly a leaky injector, or a leaky fuel pressure regulator. You can check the regulator by pulling the vacuum hose off of it and checking for the presence of fuel, if the end of the hose is damp or dripping with gas, the fp reg must be replaced. (fp reg is located in the middle of the driver's side fuel rail)
Old Oct 17, 2005 | 11:32 PM
Gmc²'s Avatar
thanks ill check that out
Old Oct 18, 2005 | 03:20 PM
Gmc²'s Avatar
not the fuel regulator i did what you said
Old Oct 18, 2005 | 05:49 PM
budhayes3's Avatar
PT's Slowest Truck
Darn...should've known that would be too easy Not sure how rusted in your O2's are...but if they're not too bad you could always remove them and swap sides, then clear the code. If the same code comes up, you know it's not the O2 sensor, if the code comes up rich on bank2, you nailed it as a bad O2
Cowboy Tom
24
Feb 11, 2017 08:20 PM
supercharged680
Jan 17, 2011 05:41 PM
1SlowHoe
51
Sep 8, 2007 11:51 AM
Tootall
Aug 1, 2007 05:35 PM
Flem
Aug 26, 2003 05:58 PM
