Open Loop Question
What tuning suite are you using? I use HPT, I dont have a delay in seconds, Not all but some newer trucks will not enter PE for about 60 seconds when PE Enable TQ is 100%. Fix is to lower it or set at 0%. I assume we are talking about the same table just different vender?
I am using HP tuners and I do not see anything about a delay in seconds or PE enable tq I do see a PE enable RPM, Delay RPM, and PE enable TPS Hot. Which table is it that I need to change?
Originally Posted by Wilde Racing
Engine > Fuel Control > Power Enrich > Delay RPM
Delay RPM set to 0
Enable torque set at 0
Delay RPM set to 0
I see the Delay RPM table but I have not been able to find the Enable torque table!
Originally Posted by 1slowsilverado
What version are you using? We didnt get this table untill the second update of 2.0. Should be,
Map
Map Hyst
Delay RPM
Enable TQ, Needs to Be 0, Not 100%
TQ Hyst, 0
Map
Map Hyst
Delay RPM
TQ Hyst, 0
I have 2.1
