OEM 05+ e-fan harness on 99-02 trucks
Old Aug 5, 2011 | 06:21 AM
Toaders's Avatar
Default OEM 05+ e-fan harness on 99-02 trucks
Can an OEM 05+ efan harness be put on a 99-02 truck? Are the airbag sensors and the connectors for the headlights the same? Can it be adapted right to the existin fuse block? I have the harness it looks like its going to be a bitch to install. Currently running a standard e-fan harness from a vendor on here. Thanks
Old Aug 5, 2011 | 02:45 PM
slowec's Avatar
Why not use the vendor harness and the 05 fans?
Old Aug 7, 2011 | 06:55 AM
Suburbazine's Avatar
No, not without replacing several other wiring harnesses and the fuse panel. The 99-02's aren't "pre-plumbed" so to speak for e-fans. You're much better off using an aftermarket harness.
Old Aug 13, 2011 | 03:43 PM
Toaders's Avatar
So i was looking closer at the harness and you can use it. The fan harness is actual a seperate harness and can be removed from the main front harness. Just un loom the fan part and you can remove the entire fan harness. Now i can adapt it to my 00 harness.
Old Aug 13, 2011 | 07:09 PM
So you've got the expanded fuse/relay panel ready to go and wiring to the PCM for the fans? Cool.
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
01sierraon22s
Jul 8, 2015 11:26 AM
GreyChevy
Jul 7, 2015 08:57 PM
