OBD II Pin assignments
Old Aug 31, 2006 | 06:49 AM
dewmanshu's Avatar
Moderately Differentiated
Default OBD II Pin assignments
anybody have the power assignments to the pins in the port? 2000 silverado
Old Aug 31, 2006 | 07:47 AM
dewmanshu's Avatar
How does this look?
The OBD-II specification provides for a standarized hardware interface—the female 16-pin (2x8) J1962 connector. Unlike the OBD-I connector, which was sometimes found under the hood of the vehicle, the OBD-II connector is always located on the driver's side of the passenger compartment near the center console. SAE J1962 defines the pinout of the connector as:
  1. -
  2. Bus positive Line of SAE-J1850
  3. -
  4. Chassis ground
  5. Signal ground
  6. CAN high (ISO 15765-4 and SAE-J2234)
  7. K line of ISO 9141-2 and ISO 14230-4
  8. -
  9. -
  10. Bus negative Line of SAE-J1850
  11. -
  12. -
  13. -
  14. CAN low (ISO 15765-4 and SAE-J2234)
  15. L line of ISO 9141-2 and ISO 14230-4
  16. Battery voltage
The assignment of unspecified pins is left to the vehicle manufacturer's discretion.
Old Aug 31, 2006 | 11:15 PM
1slowsilverado's Avatar
Yup thats correct and pretty much covers the 3 protocols Your trucks uses SAE J1850 VPW (Variable Pulse Width Modulation)
Pin 2 - J1850 Bus+
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 14 - CAN Low
Pin 16 - Battery Power
Pin 9 is the mystery pin witch is a UART line for seiral data...
Porscharu914
14
Jan 20, 2016 10:45 AM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
kalikid06
Sep 20, 2015 07:46 PM
99bluefirebird
Sep 17, 2015 08:05 PM
