O2 sensor failure???
Old Sep 8, 2007 | 07:00 PM
spinz71's Avatar
Default O2 sensor failure???
Besides the obvious codes to indicate failure of a B1 or B2 NBO2 sensor, are there any indicators that one is going bad? Do they "degrade" or just "fail"?
If you were bumping 90K miles on the originals would there be any REAL...IMMEDIATE benefit in replacing them?
Old Sep 8, 2007 | 10:10 PM
blown3qtr's Avatar
Sometimes when they are going bad the readings can be "lazy". If you have a scanner you can watch the O2 voltage fluctuate from +- 200-800mv radidly. So fast that you can't really pick out a single value at any instance. If the voltage fluctuates slowly then you probably have a bad O2 sensor. I've put over 200k on mine.
Old Sep 9, 2007 | 06:01 PM
spinz71's Avatar
Thanks! I appreciate the info.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
