No Tach
No Tach
So I noticed the tach wasn't working about a week ago I hooked up the old Torque pro and it shows no codes other then my knock senor bad but it does show the computer is getting a tach signal it shows up on it. And the tach needle does wiggle. Any ideas?
according to a couple places ive called or emailed the 99-02 doesnt have stepper motors like the 03 and up and dont really have that problem. i have hooked up the torque app and the computer is getting the signal but not the instrument cluster and so im lost every once in a while it will work for 30 seconds maybe a minute then gone so idk i need help
I'm just explaining why you can show RPM with a scan tool but no dash tach. Since it's intermittent I would look at the pin in the PCM connector. Clusters come out easy too. You might try reseating the cluster connector or look for a broken solder on the cluster circuit board.
So I bought another Speedo cluster mainly because I wanted the trans temp gauge but the tach is still not working so any other ideas. Someone on another forum said the Ign Switch does that make sense to anybody.
