No power to passanger door
Old Aug 27, 2006 | 10:36 PM
skamps33's Avatar
Default No power to passanger door
Does anybody have any ideas what could be the problem, My keyless entry does not work on any of the doors now since I loss all power to the passanger door. The window will not work and the heated seat does not have any power. I have checked all fuses and all is OK. Has anybody had this problem before. Could it be something with the keyless entry perhaps? Any advice would help.
Thanks,
P.S. The driver power switch will lock all doors and roll down all windows except passanger door lock and window.
Old Oct 13, 2007 | 11:54 PM
bsm02ws6's Avatar
My father in-law's 2003 Silverado just recently started having the same problem. His remote keyless entry stopped working and there's no power to the passenger side door lock or window. The dome light doesn't even come on when you open the passenger door. Did you happen to find the cause of the problem?
Thanks
Old Oct 14, 2007 | 01:35 AM
tylerj's Avatar
I had a similar problem on an 07 classic the plug had come out from the switch, you have to pull the whole door panel off on the 03 up but, on the 02 down u can just pry th switch panel off. Hope this helps .
Corvette454l88
Sep 1, 2016 01:24 AM
lycominghunter
Nov 13, 2015 10:09 PM
Ketis
Jul 23, 2015 12:37 PM
