NNBS Standalone Harnness & BCM ??
Old Sep 2, 2011 | 10:35 PM
v502's Avatar
Default NNBS Standalone Harnness & BCM ??
Hey just wondering if any of Gurus out there has any input on this?
I am going standalone harness with Holley Dominator EFI for twin turbo NNBS.
I know that guage's wont work which is okay but would love to keep the AC. The only problem that it is controlled by the BCM and I want to gut out the stock ECU and engine harness and worried that the BCM will freak out and stop working.
Any Input will be helpful ?
Old Sep 3, 2011 | 12:35 PM
CalEditor@PCMCalibrators's Avatar
FormerVendor
What year is the truck?
Old Sep 4, 2011 | 02:56 PM
v502's Avatar
RC 2007 2wd 5.3
Old Sep 4, 2011 | 07:00 PM
FormerVendor
If it is a GMT 900 I would run the OE ECM on that truck.
If it is a GMT 800 I would run the OE PCM, but it may take a little more work than the 900
Old Dec 21, 2011 | 11:56 AM
Phantom's Avatar
11 Second Club
Anymore info on this? Is the BCM going to freak out without the pcm being attached to it?
Old Dec 22, 2011 | 12:41 AM
Blown06's Avatar
8 Second Truck Club
Its possible to do. Nelson did it on a newer truck, but with a standalone factory pcm and harness from an F-body. He used aftermarket gauges and I'm sure the a/c was gone.
Old Dec 22, 2011 | 11:38 AM
The only way to do it is with the pcm as a stand alone controller for the major vehicle subsystems. If you take it out completely you get to roll down the windows.
The interior HVAC will stay working correctly but it cannot control the compressor without the pcm. Your only option would be to put a toggle switch on the compressor with the compressor safeties wired in series with the ground signal to the added relay coil.
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Jr. SXT
Sep 30, 2015 07:23 PM
Gmc_sierra
Sep 13, 2015 10:02 PM
