need some quick help
Old Sep 27, 2008 | 12:45 PM
Jeteys5.3's Avatar
Default need some quick help
just installed my blackbear PCM just now. But i got confused on one thing, the color coded connectors....i installed them and they screwed right in and i got them snug didnt wanna force them too tight. But can they both go either way into the pcm....like say it goes in one way can you flip it around and go in just as good? or do they have to be a certain way? cause the one has the flat corner pointing to me but the other one has the square cutout on the side of it facing me. I was just wondering if i needed to turn either around to match right...hope you understand what i mean.
Old Sep 27, 2008 | 12:55 PM
viciousknid's Avatar
Where's the Beef?
I don't know if they will bolt in both ways but with the wires being as stiff as they are how can you get it twisted around without knowing? They should hold position.
Old Sep 27, 2008 | 01:11 PM
Fireman31's Avatar
As you are looking down on the PCM, the blue connector goes on the left and the green on the right....the blue connector should have the harness coming out on the bottom and the green on top. The two 7mm bolt takes care of snugging each connector down, and should be hand tight.
Old Sep 27, 2008 | 09:45 PM
Jeteys5.3's Avatar
yeah i got it no problem, just confused me for a second. But for tightening them, i just got them to where they were snug with the ratchet, didnt want to overtorque them
drummer0415
11
Oct 24, 2015 08:16 PM
Wrecker 426
Oct 7, 2015 12:11 PM
01silvy
Sep 26, 2015 10:20 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
