Need some help with tuning. EFILive
Old Oct 30, 2007 | 08:44 PM
dc_justin's Avatar
Hello Dave
Originally Posted by gao8302
Is there a good starting point at which i should start with the timing adjustment. Thanks for the help. Im all for learning. How did you know that? I want to learn as much as i can for you and everyone else.
To really set timing properly, you need to use a load bearing dyno. Otherwise, err on the side of safety and lower the timing.
Your High Octane Table is reasonable, thus I'd start out by zeroing out your fuel mixture spark correction table.
Old Oct 30, 2007 | 08:50 PM
gao8302's Avatar
Is there any other way to do this without a dyno? There isnt one close. So just zero out the whole table then for now? Anything else that draws your thoughts off hand.
Old Oct 30, 2007 | 08:54 PM
dc_justin's Avatar
Hello Dave
That's the biggie right there.
As far as timing. You can get it running decent without a dyno, but you can't get your timing perfect without one. It's important to be sure that you're not knocking audibly nor seeing any KR.
Justin
Old Oct 30, 2007 | 08:56 PM
gao8302's Avatar
Thanks for the help. I will get up a few more logs.
Old Oct 30, 2007 | 09:00 PM
DrX's Avatar
DrX
Looks like we are not receiving notifications with respect to subscribed threads.
Thanks DC Justin. Sometimes I forget that everyone with boost and tuning software is not running a 2 bar custom OS.
GM.AFR(commanded air fuel ratio) should be in the PID list. Did you Validate the PIDs with the FlashScan connected to your vehicle? (INFO> Validate PIDs)
The IFR table does need to be correct. I have seen these injectors setup anywhere from 5.0 - 5.3 g/s. Lower will get you more fuel.
Stay out of boost until the knock issue gets sorted out. Can you hear the knock? Is this a fresh blower install?
Edit: Boy you guys were busy while I was typing!
Old Oct 30, 2007 | 09:16 PM
gao8302's Avatar
Just got back for a little drive and a log. As you can see i cant wait to get this KR issue taken care of. Im still seeing KR. The log is a cruise and a short wot run. Like DR.x said no more wot run till this is taken care of.
File Type: efi
Old Oct 30, 2007 | 09:19 PM
gao8302's Avatar
I cant hear the knock and its not a fresh blower install. I ditch the whipple craptronics. The cam is new though along with the injectors.
Old Oct 30, 2007 | 09:26 PM
dc_justin's Avatar
Hello Dave
Oh, you're lean in boost. If I had to guess based on your narrowband voltage (not reliable), I'd guess you're sitting at around 13.3-13.6:1 AFR in boost. Is the MAF stock?
Don't go anywhere NEAR boost until that is fixed.
Old Oct 30, 2007 | 09:31 PM
gao8302's Avatar
THe maf is stock unmodified. I have a Aem wideband on its way. It looked to me if im reading it right that I was still getting kr at a low rpm. what is causing that? Spark still? What do i have to adjust when i get my wideband? Im learning alot hear as we are talking.
Old Oct 30, 2007 | 09:32 PM
gao8302's Avatar
Should i tune down my IFR chart to make it richer? Im thinking im having more problems than just that.
