More Transmission tuning Questions
Old Mar 2, 2008 | 10:35 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default More Transmission tuning Questions
Shift pressure...
Where do you guys set the max value in "shift pressure-normal" ??
I turned up the "MAX PRESSURE" value to 96 (from 90) so it would make sense to have the cells in the upper range of the torque scale set to a higher # to take advantage of increased line pressure? Am I like a totally off-base newbie or what?
Old Mar 2, 2008 | 10:44 AM
Klive's Avatar
Banned
I have wondered on this also, I didn't want to have it to high with my stock trans still in the truck but good question, glad someone else asked it!!
Old Mar 2, 2008 | 11:06 AM
KySilverado's Avatar
90 is the stock setting and where I have mine. But yeah if you want to bump it up you would need to raise it in the other tables also. Not needed IMO with a built tranny.
Old Mar 2, 2008 | 11:42 AM
trever1t's Avatar
Thanks Roger!
Old Mar 2, 2008 | 07:57 PM
TouchOfEvil04's Avatar
Lol, my two trucks shift so dang hard i have all lowered across the board.
the rcsb is at 0 for about half the table.
Old Mar 3, 2008 | 12:00 AM
Sleeper Bowtie's Avatar
I don't know much about the rest of HP tuners but the transmission tuning was very important to me.When i had John from Magnacharger tune my truck we drove around for about 2.5 hours working on air/fuel ratio and trans tuning.Anything over 400ft.lb he set at 96 and i think it finally shifts the way i want it too.
Old Mar 3, 2008 | 08:40 AM
trever1t's Avatar
Yeah, that's what i was thinking here, setting the Max pressure tab to 96 and pressure field to 96 in the upper cells of the field.
Any more thoughts?
Old Jun 8, 2008 | 04:12 PM
FL-Pirate's Avatar
10 Second Club
Any more thoughts?
How did you make out with this? I've successfully tuned out the TM and now working on the line pressure. Where did you end up? Thanks.
Old Jun 8, 2008 | 04:44 PM
BlackGMC's Avatar
Resident Retard
Before you guys go start changing values in that table you need to log delivered engine torque so you know what cell to modify... Delivered engine torque is calculated by the computer, so with that said you may not even be getting to the 640tq cell....
Old Jun 8, 2008 | 05:07 PM
trever1t's Avatar
well, as logged I reach the lower 500-520 foot/lbs when wot.
In this screen shot the top table are the stock settings and the lower is my current shift pressure table. Notice I had to turn the pressure down in the lower range, it shifts crisp and quickly now. At wot the increased pressure is not rough. Everything "feels" good.
