Mail Order Tune and Boost work?
Old Aug 8, 2013 | 08:08 PM
subeone's Avatar
does it have a return style setup? external fuel pressure regulator? 07 4.8 as in nnbs? no cam? drive by cable im assuming
Old Aug 8, 2013 | 08:12 PM
kelsey_canard's Avatar
Stock return style rails with stock regulator. 4.8 classic with the stock 99dbc theottlw body and intake manifold. Stock cam with yellow springs and hardened pushrods.
Old Aug 8, 2013 | 08:30 PM
Jimmy_d's Avatar
Yeah what he said^. Im a loser and bought someone elses truck!
Old Aug 8, 2013 | 08:37 PM
subeone's Avatar
im using 42 ford lb injector data hopefully those are the ones he is using
Old Aug 8, 2013 | 08:39 PM
He's using ls7s I'm pretty sure.
Old Aug 8, 2013 | 09:02 PM
subeone's Avatar
try this i guess, i wouldnt know why you have trouble turning on the vehicle everything seems "fine" to an extent. added some airflow and edited tables.
Edit: i used green top ford 42 injector data... lol let me see if i can edit this file with ls7 data
Old Aug 8, 2013 | 09:11 PM
subeone's Avatar
this should work, its for ls7 injectors
Old Aug 8, 2013 | 09:31 PM
That's kind of my thoughts. I'll check over your revision in a few. I've really been thinking its a mechanical problem. The throttle blade has been messed with. I have set the blade where the IAC falls close to 140. The IAC counts really won't move appropriately IMO. Tried replacing it, and same thing. Any other ideas?
Old Aug 8, 2013 | 10:10 PM
Tune looks pretty good. Any reason why ltfts are disabled though?
Old Aug 9, 2013 | 12:08 AM
subeone's Avatar
since you were previously running rich, it would want to take out fuel so in this case if the fueling is a little close, the ltft's would remove fueling and with the file i gave you would make it run lean to an extent.
