LTFT's high suddenly???
My LTFT's have been around -1.6% at idle for years now. I did a log trying to resolve another issue and noticed that they are at 10% on one bank and 15% on the other at idle. I have checked and eliminated the following:
spark plugs
plug wires
connections
vacuum leaks
maf sensor
I am replacing the o2 sensors as they have 114,000 miles on them. I do not get any codes and the tune is fine other than idle. I get a high count in the misfire index as soon as I step on the gas but it goes away instantly and then the LTFT's go to -1% normal driving.
What else can I check??
spark plugs
plug wires
connections
vacuum leaks
maf sensor
Sure hope its not that, I just replaced it a few months ago!! Ill check that thanks!
Weird thing is yesterday everything cleared up and the LTFT's went back to 0%. Then today they are back to +15%.
I replaced ALL of the vacuum lines. Checked the manifold, exhaust and intake for leaks. I checked fuel pressure, replaced the fuel filter and ran seafoam through the fuel system.
I replaced the EGR gasket and cleaned the valve as well. How do I test to see if the EGR and MAF are functioniong as they should?
