LTFT B1 and B2 big difference
Old Mar 4, 2008 | 07:43 PM
Klive's Avatar
Banned
Default LTFT B1 and B2 big difference
I did a WOT scan today and there is a quite large discrepancy between B1 and B2 at WOT B1 is 23.4 B2 is 9.3... the STFT's are both 0.0 the entire WOT pull. Any insight on the difference in the LTFT?
Old Mar 4, 2008 | 07:52 PM
Stoichiometric's Avatar
Probably a bad O2, how many miles are on them?
Old Mar 4, 2008 | 08:02 PM
Klive's Avatar
Banned
~110k!! if that were the case wouldn't there be some difference in the STFT?
Old Mar 4, 2008 | 08:07 PM
BlackGMC's Avatar
Resident Retard
I think STFT do not work at WOT... Also I think at WOT what ever the last reading of your LTFT were that is what it uses during the entire WOT pull. This is why it is important to have your VE table tuned correctly... Try switching your O2 sensors and drive it a couple of days and see if the numbers swap sides... If they switch sides then you have a bad O2 sensor, if they don't then more than likely you have an exhaust leak.
Old Mar 4, 2008 | 08:11 PM
Klive's Avatar
Banned
ahh, thats probably why they go to zero at WOT (but they show 0.0 at partial throttle at times also. I'm pretty sure I have an exhaust leak I need to tighten the collector bolts, I'm going to go ahead and get a new set of sensors, these are 100k+ and have served well but I think its time to upgrade.
Old Mar 4, 2008 | 11:29 PM
mcfarlnd's Avatar
Un-Registered User
regardless u should probably get your ve in check with a live tune
Fast86z
Aug 23, 2015 12:35 AM
urdone
Aug 16, 2013 07:33 PM
charcoal03silvy
May 19, 2012 07:59 AM
Yelo
Jan 30, 2009 09:40 PM
dc_justin
Aug 29, 2005 10:49 PM
