The LQ9 that wouldn't ...
So i finally swapped in the 6.0 and it ran to the car wash, back to the house, and for a littlefun test drive, but now nothing. Its acting as if the battery is dead, but the batt is reading 12.8.
Tested the starter and alt...both good. Got the batt tested and it came out good as well. Been going through checking grounds but all seem to be where they should. Anyone ave any ideas???
Im stuck.
Im stuck.
if you are getting 12.2v on a volt meter while the truck is sitting then you need to hit the key while someone watches the volt meter to make sure that it's not dropping below 10.9v if it is then change the battery. if its doing fine but not starting still, THEN:
jump the starter at the fuse box.
pull the starter relay *make sure you put it back the same way* jump 87 to 30 if it still does the same thing then you need to pull the starter and put a ground to it then 12v to it and jump it with a wire from the ign to 12v while the starter is in a vice.
