LQ9 help needed "tuning"
Old Dec 27, 2015 | 02:06 PM
harley63's Avatar
Registered User
Default lq9 help needed
I have a 2000 Silverado 4x4 and just installed a 2002 Escalade EXT 6.0 LQ9.
My question is I still have the stock computer that was in the truck.The truck was a LQ4 6.0.The truck runs great but was wondering if I need the escalade ecm or a tune.
Old Dec 27, 2015 | 02:09 PM
harley63's Avatar
Registered User
Just trying get the most out this combo.The truck has duel exhaust with stock manifolds cats and Borla mufflers.
Old Dec 27, 2015 | 02:22 PM
03sierraslt's Avatar
Your ECM will work fine, but I would get a good tune to optimize fueling and timing and to fine tune everything. Those two engines were different compression so a tune should be on your to do list.
Old Dec 27, 2015 | 02:28 PM
harley63's Avatar
Registered User
Does anyone no of a good tuner in the Seattle Tacoma area? Preferably a GM tuner.
Old Dec 27, 2015 | 03:32 PM
George C....'s Avatar
Formerly ScreamingL
Honeslty a 2000 6.0 swapped for a another shouldnt require a tune
Only change was .5 compression...not enough to worry
Old Dec 27, 2015 | 03:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Yes I would have it tuned. That's the only way you will get the most out of it.
Old Dec 27, 2015 | 03:52 PM
Formerly ScreamingL
You dont have to tune it but if you want it tuned it will pic up some power
Old Dec 27, 2015 | 04:17 PM
harley63's Avatar
Registered User
Hey thanks for the input! I think I am going to add a new cam then have it tuned. Any suggestions for a mild cam that will wake this thing up. Not looking to drag race just lurk in the shadows.LOL
Old Dec 30, 2015 | 09:34 AM
2002_Z28_Six_Speed's Avatar
I have EFI Live and I compared two of the LQ4 and LQ9 files from Holden Crazy with the same OS. Keep in mind that other LQ9 files out there could be different from the comparison.
I checked the VE table and the MAF table and they were 100% the same. Here is a comparison.
Comparison summary: 10.36.32 am, Wednesday Dec 30, 2015
Calibration comparison between 2003 Chevrolet Silverado Truck Automatic LQ4 6.0 Litre (12579405).ctz and 2003 Chevrolet Silverado Truck Automatic LQ9 6.0 Litre (12579405) (1).ctz.
B1201 "Abuse Management (in Gear) Upper RPM Threshold" -1.562524 "CAL: 1400 ALT: 1600"
B1202 "Abuse Management (in Gear) Lower RPM Threshold" 1.562524 "CAL: 1200 ALT: 1000"
B1203 "Abuse Management (in P/N) Upper RPM Threshold" -1.562524 "CAL: 1400 ALT: 1600"
B1204 "Abuse Management (in P/N) Lower RPM Threshold" 1.562524 "CAL: 1200 ALT: 1000"
B1209 "Abuse Management Time" -0.170901 "Different from row 0 to row 15 inclusive."
B3642 "After-start Coolant Temp Enrichment" 0.096132 "Different from cell: 0,5 to cell: 4,6 inclusive."
B3650 "After-start Enrichment Decay Factor" 1.098633 "Different from cell: 0,6 to cell: 4,7 inclusive."
B3330 "Fuel Cut-off in P/N" -2.343786 "CAL: 5700 ALT: 6000"
B3331 "Fuel Re-enable in P/N" -2.343786 "CAL: 5650 ALT: 5950"
B3322 "VSS Failed RPM Limit Upper" -2.343786 "CAL: 5700 ALT: 6000"
B3323 "VSS Failed RPM Limit Lower" -2.343786 "CAL: 5650 ALT: 5950"
B3303 "Fuel Cut-off Limiters in Gear" -2.343786 "Different from cell: 0,0 to cell: 1,9 inclusive."
B5401 "ETC Controlled RPM Limit" -2.343786 "Different from row 0 to row 9 inclusive."
B3319 "DFCO RPM Hysteresis" 0.390631 "CAL: 150 ALT: 100"
B3318 "DFCO RPM" 0.781262 "Different from cell: 0,0 to cell: 1,9 inclusive."
B3618 "PE Modifier Based on RPM" 0.294676 "Different from row 0 to row 18 inclusive."
B3659 "Commanded Fuel When in Piston Protection Mode" 0.294676 "Different from row 0 to row 20 inclusive."
B3608 "Delay before Entering PE Mode" 14.648661 "CAL: 60 ALT: 0"
B3653 "Piston Protection RPM Limit" -0.781262 "CAL: 2000 ALT: 2100"
B4601 "Max Idle RPM in Gear" 0.976577 "CAL: 1200 ALT: 1075"
B4602 "Max Idle RPM in P/N" 0.976577 "CAL: 1200 ALT: 1075"
B4403 "IAC Effective area" 3.250000 "Different from row 8 to row 56 inclusive."
B4603 "Desired Idle Speeds" 0.390631 "Different from cell: 0,10 to cell: 3,13 inclusive."
B4605 "Heater Warmup RPM Offset" -0.195315 "Different from cell: 1,10 to cell: 1,10 inclusive."
B4338 "Engine Speed Compensation" -3.656062 "Different from cell: 0,1 to cell: 1,11 inclusive."
B4307 "Desired Airflow" 3.125048 "Different from cell: 0,0 to cell: 1,9 inclusive."
B4353 "Idle Spark Control Delay" 0.256352 "Different from row 0 to row 16 inclusive."
B4360 "A/C Torque Loss Correction" -0.027466 "Different from row 3 to row 13 inclusive."
B4362 "A/C Clutch Off Spark Delay" -0.012207 "Different from row 3 to row 3 inclusive."
B4363 "A/C Clutch Off Spark Torque Disable" 1.176471 "Different from row 3 to row 3 inclusive."
B4364 "A/C Clutch On Spark Torque Enable" 1.568627 "Different from row 2 to row 13 inclusive."
B4369 "A/C Clutch Spark Torque Retard Limit" 21.337509 "Different from cell: 3,1 to cell: 5,9 inclusive."
B4304 "Startup Airflow Correction" -0.781262 "Different from row 4 to row 4 inclusive."
B4502 "Idle Learn Maximum Temperature" 6.663773 "CAL: 112 ALT: 100"
B4514 "Learned Airflow Correction" 0.001526 "Different from cell: 2,2 to cell: 3,3 inclusive."
B4321 "Throttle Follower TPS change" 0.292969 "CAL: 1.00 ALT: 0.70"
B5913 "Spark High-Octane Table" -13.727679 "Different from cell: 0,0 to cell: 28,24 inclusive."
B5914 "Spark Low-Octane Table" 14.376395 "Different from cell: 0,0 to cell: 28,24 inclusive."
B5932 "Base Spark in Gear" -8.754730 "Different from cell: 0,0 to cell: 28,12 inclusive."
B5933 "Base Spark in Park/Neutral" -8.754730 "Different from cell: 0,0 to cell: 28,12 inclusive."
B5910 "Spark ECT Table" 5.566406 "Different from cell: 5,0 to cell: 28,33 inclusive."
B5911 "Spark IAT Table" -2.221680 "Different from cell: 7,9 to cell: 28,16 inclusive."
B5943 "Spark IAT vs RPM Multiplier" -24.999997 "Different from row 2 to row 14 inclusive."
B5944 "Spark IAT vs ECT Multiplier" -64.990228 "Different from row 28 to row 36 inclusive."
B5907 "EGR Spark Correction" -9.448242 "Different from cell: 1,7 to cell: 9,12 inclusive."
B5908 "Fuel Mixture Spark Correction" -6.713867 "Different from cell: 0,4 to cell: 20,15 inclusive."
B5945 "Cold Engine Noise Reduction Timing" 3.881836 "Different from cell: 2,3 to cell: 5,10 inclusive."
B5919 "Optimal Timing" 6.689453 "Different from cell: 0,0 to cell: 14,19 inclusive."
B5901 "Catalytic Converter Light-off" -5.322266 "Different from cell: 0,2 to cell: 28,16 inclusive."
B5935 "Idle Overspeed Error" 0.772476 "Different from row 1 to row 3 inclusive."
B5936 "Idle Underspeed Error" 0.978470 "Different from row 6 to row 8 inclusive."
B5948 "Burst Knock Timing" 3.433228 "Different from cell: 0,0 to cell: 5,11 inclusive."
B1901 "Max Allowed Engine Torque" -7.812619 "CAL: 474 ALT: 610"
B6615 "Max Torque, Front Axle" 0.005169 "CAL: 12647 ALT: 9709"
B6616 "Max Torque, Rear Axle" 0.005562 "CAL: 13549 ALT: 10388"
B6618 "Max Torque, Rear Prop Shaft" 0.000949 "CAL: 3700 ALT: 3161"
B6619 "Max Torque, Trans Input Shaft" 0.000513 "CAL: 1199 ALT: 908"
B6620 "Max Torque, Trans Output Shaft" 0.000303 "CAL: 2783 ALT: 2611"
B6606 "ETC TCS Exit Rate" 0.171661 "CAL: 1.0 ALT: 0.8"
B6605 "TCS Spark Retard Torque Loss" 2.746582 "Different from cell: 0,5 to cell: 4,32 inclusive."
B6612 "ETC Pedal Torque Limit Reduction" 55.996094 "Different from cell: 0,0 to cell: 15,20 inclusive."
B6614 "Max Torque By RPM" -2.943465 "Different from cell: 0,0 to cell: 4,20 inclusive."
B2307 "ETC Pedal Response - Primary" -15.498047 "Different from cell: 0,1 to cell: 9,29 inclusive."
B2308 "ETC Pedal Response - Alternate" -15.498047 "Different from cell: 0,1 to cell: 9,29 inclusive."
C6001 "Engine DTC Processing Enablers" N/A "Different from row 11 to row 230 inclusive."
C6002 "Engine DTC MIL Enablers" N/A "Different from row 11 to row 230 inclusive."
C3208 "Post-catalyst O2 Transition time - first" 26.666667 "CAL: 11 ALT: 3"
C3209 "Post-catalyst O2 Transition time - second" 18.000000 "CAL: 8 ALT: 2"
C5605 "Misfire Detection Max RPM" -2.343786 "CAL: 5250 ALT: 5550"
C5606 "Misfire Detection Min RPM" 0.195315 "CAL: 425 ALT: 400"
C5621 "Misfire Idle per Cylinder Mode" -0.671397 "Different from cell: 1,2 to cell: 9,16 inclusive."
C5622 "Misfire Low RPM per Cylinder Mode" -0.671397 "Different from cell: 1,2 to cell: 9,16 inclusive."
C5623 "Misfire Mid RPM per Cylinder Mode" -49.983978 "Different from cell: 0,2 to cell: 12,16 inclusive."
C5626 "Misfire Mid RPM per Revolution Mode" -49.968719 "Different from cell: 9,1 to cell: 22,16 inclusive."
C6101 "ETC Predicted Airflow" -1.953155 "Different from cell: 1,1 to cell: 10,16 inclusive."
D1201 "1st Gear Ratio" -7.211523 "CAL: 2.482 ALT: 3.059"
D1202 "2nd Gear Ratio" -1.788384 "CAL: 1.482 ALT: 1.625"
D1204 "4th Gear Ratio" 0.668355 "CAL: 0.750 ALT: 0.697"
D1205 "Rev Gear Ratio" -2.716147 "CAL: 2.077 ALT: 2.294"
Old Dec 30, 2015 | 09:35 AM
D1206 "WOT Shift Mode Upper Threshold" -3.750725 "CAL: 90 ALT: 94"
D1208 "WOT Shift Mode Upper Threshold - Cruise" -3.750725 "CAL: 90 ALT: 94"
D4601 "Shift Stabilization Ratios" -1.803125 "Different from row 0 to row 3 inclusive."
D0901 "Part throttle 1->2 Shift Speeds" -1.171893 "Different from cell: 0,0 to cell: 3,16 inclusive."
D0902 "Part throttle 2->3 Shift Speeds" 1.367208 "Different from cell: 0,0 to cell: 3,16 inclusive."
D0903 "Part throttle 3->4 Shift Speeds" -62.500953 "Different from cell: 0,0 to cell: 3,16 inclusive."
D0906 "Part throttle 2->1 Shift Speeds" 1.562524 "Different from cell: 0,0 to cell: 3,16 inclusive."
D0907 "Part throttle 3->2 Shift Speeds" -5.859464 "Different from cell: 0,0 to cell: 3,16 inclusive."
D0908 "Part throttle 4->3 Shift Speeds" -70.313572 "Different from cell: 0,0 to cell: 3,16 inclusive."
D0910 "WOT 1->2 Shift Speeds, Normal" -3.125048 "CAL: 40 ALT: 53"
D0911 "WOT 1->2 Shift Speeds, Performance" -3.125048 "CAL: 40 ALT: 53"
D0912 "WOT 1->2 Shift Speeds, Hot" -3.125048 "CAL: 40 ALT: 53"
D0915 "WOT 2->3 Shift Speeds, Normal" -3.125048 "CAL: 89 ALT: 101"
D0916 "WOT 2->3 Shift Speeds, Performance" -3.125048 "CAL: 89 ALT: 101"
D0917 "WOT 2->3 Shift Speeds, Hot" -3.125048 "CAL: 89 ALT: 101"
D0964 "WOT 2->3 Shift Speeds, 4WD Low" -3.906310 "CAL: 40 ALT: 56"
D0919 "Manual Hold Gear, 2nd, 2->3 Shift Speeds" -0.389105 "CAL: 410 ALT: 412"
D0920 "WOT 3->4 Shift Speeds, Normal" -70.313572 "CAL: 121 ALT: 410"
D0921 "WOT 3->4 Shift Speeds, Performance" -70.313572 "CAL: 121 ALT: 410"
D0922 "WOT 3->4 Shift Speeds, Hot" -70.313572 "CAL: 121 ALT: 410"
D0965 "WOT 3->4 Shift Speeds, 4WD Low" -3.906310 "CAL: 80 ALT: 97"
D0914 "Manual Hold Gear, 2nd, 1->2 Shift Speeds" 15.625238 "Different from row 15 to row 16 inclusive."
D0925 "WOT 2->1 Shift Speeds, Normal" 0.781262 "CAL: 56 ALT: 53"
D0926 "WOT 2->1 Shift Speeds, Performance" 1.562524 "CAL: 60 ALT: 53"
D0927 "WOT 2->1 Shift Speeds, Hot" 0.781262 "CAL: 56 ALT: 53"
D0966 "WOT 2->1 Shift Speeds, 4WD Low" 3.515679 "CAL: 24 ALT: 10"
D0928 "Manual Downshift 2->1 Shift Speed" 1.562524 "CAL: 64 ALT: 58"
D0930 "WOT 3->2 Shift Speeds, Normal" 0.585946 "CAL: 103 ALT: 101"
D0931 "WOT 3->2 Shift Speeds, Performance" 0.585946 "CAL: 106 ALT: 104"
D0932 "WOT 3->2 Shift Speeds, Hot" 2.343786 "CAL: 106 ALT: 97"
D0967 "WOT 3->2 Shift Speeds, 4WD Low" 2.343786 "CAL: 48 ALT: 39"
D0933 "Manual Downshift Gear 3->2 Shift Speeds" -72.266727 "CAL: 113 ALT: 410"
D0935 "WOT 4->3 Shift Speeds, Normal" -66.407263 "CAL: 137 ALT: 410"
D0936 "WOT 4->3 Shift Speeds, Performance" -66.407263 "CAL: 137 ALT: 410"
D0937 "WOT 4->3 Shift Speeds, Hot" -66.407263 "CAL: 137 ALT: 410"
D0968 "WOT 4->3 Shift Speeds, 4WD Low" 12.890822 "CAL: 121 ALT: 68"
D0940 "WOT 1->2 Shift RPM, Normal" -4.882962 "CAL: 5200 ALT: 5600"
D0969 "WOT 1->2 Shift RPM, 4WD Low" 17.090365 "CAL: 4400 ALT: 3000"
D0970 "WOT 2->3 Shift RPM, 4WD Low" 17.090365 "CAL: 4400 ALT: 3000"
D0950 "WOT 3->4 Shift RPM, Normal" -41.404462 "CAL: 4800 ALT: 8192"
D0951 "WOT 3->4 Shift RPM, Performance" -41.404462 "CAL: 4800 ALT: 8192"
D0952 "WOT 3->4 Shift RPM, Hot" -41.404462 "CAL: 4800 ALT: 8192"
D0971 "WOT 3->4 Shift RPM, 4WD Low" 21.973327 "CAL: 4800 ALT: 3000"
D0960 "2->1 Throttle Kickdown" -59.999389 "Different from cell: 0,1 to cell: 2,7 inclusive."
D0961 "3->2 Throttle Kickdown" -13.000885 "Different from cell: 0,1 to cell: 2,11 inclusive."
D0962 "4->3 Throttle Kickdown" 61.998352 "Different from cell: 0,1 to cell: 2,13 inclusive."
D1108 "Desired 1-2 Shift Times" -6.000000 "Different from cell: 0,0 to cell: 1,16 inclusive."
D1109 "Desired 2-3 Shift Times" 3.500000 "Different from cell: 0,0 to cell: 1,16 inclusive."
D1110 "Desired 3-4 Shift Times" 8.000000 "Different from cell: 0,0 to cell: 1,16 inclusive."
D1001 "TCC Apply Speeds - Second Gear" -91.796749 "Different from cell: 0,0 to cell: 3,16 inclusive."
D1002 "TCC Apply Speeds - Third Gear" -9.375143 "Different from cell: 0,0 to cell: 3,16 inclusive."
D1003 "TCC Apply Speeds - Fourth Gear" -72.657358 "Different from cell: 0,0 to cell: 3,16 inclusive."
D1004 "TCC Release Speeds - Second Gear" -92.578011 "Different from cell: 0,0 to cell: 3,16 inclusive."
D1005 "TCC Release Speeds - Third Gear" -6.640726 "Different from cell: 0,0 to cell: 3,16 inclusive."
D1006 "TCC Release Speeds - Fourth Gear" -70.313572 "Different from cell: 0,0 to cell: 3,16 inclusive."
D2902 "TCC Maximum Pressure" 4.687643 "CAL: 910 ALT: 827"
D2903 "TCC Solenoid Minimum PWM" 69.002350 "Different from cell: 0,0 to cell: 4,16 inclusive."
D2904 "TCC Solenoid Maximum PWM" 3.997925 "Different from cell: 0,0 to cell: 4,16 inclusive."
D2905 "TCC Pressure Apply Rate" -1.752930 "Different from row 0 to row 16 inclusive."
D0701 "Base Pressure 1->2 Shift" -40.625000 "Different from cell: 0,0 to cell: 1,32 inclusive."
D0704 "1->2 Temperature Pressure Adjust" 6.770833 "Different from cell: 0,0 to cell: 4,16 inclusive."
D0702 "Base Pressure 2->3 Shift" -33.333333 "Different from cell: 0,0 to cell: 1,32 inclusive."
D0706 "2->3 Temperature Pressure Adjust" 23.437500 "Different from cell: 0,0 to cell: 4,16 inclusive."
D0703 "Base Pressure 3->4 Shift" -12.500000 "Different from cell: 0,5 to cell: 1,32 inclusive."
D0708 "3->4 Temperature Pressure Adjust" 15.625000 "Different from cell: 0,0 to cell: 4,16 inclusive."
D0709 "4->3 Temperature Pressure Adjust" -23.437500 "Different from cell: 0,0 to cell: 4,16 inclusive."
D1101 "Low Pressure Adjust 1-2 Shift" -8.368201 "Different from row 3 to row 16 inclusive."
D1102 "Low Pressure Adjust 2-3 Shift" -8.368201 "Different from row 3 to row 16 inclusive."
D1107 "High Pressure Adjust" 23.430962 "Different from row 0 to row 16 inclusive."
D1501 "Standing Shift P/N to Drive Pressure" 62.500000 "Different from cell: 0,0 to cell: 8,8 inclusive."
D1502 "Standing Shift P/N to Reverse Pressure" 62.500000 "Different from cell: 0,0 to cell: 8,8 inclusive."
D1503 "Standing Shift Drive to Reverse Pressure" 62.500000 "Different from cell: 0,0 to cell: 8,8 inclusive."
D0801 "Torque Reduction 1->2 Shift" -40.000610 "Different from cell: 0,3 to cell: 1,16 inclusive."
D0802 "Torque Reduction 2->3 Shift" -23.001800 "Different from cell: 0,1 to cell: 1,16 inclusive."
D2001 "Abuse Mode RPM Enable" 3.051851 "CAL: 1750 ALT: 1500"
D2002 "Abuse Mode TPS Enable" 7.000946 "CAL: 12.00 ALT: 5.00"
D2003 "Abuse Mode Speed Enable" -78.126192 "CAL: 89 ALT: 410"
D2004 "Abuse Mode Torque Reduction" 29.999695 "Different from row 3 to row 7 inclusive."
E0101 "Transmission DTC Fault Processing Enablers" N/A "Different from row 3 to row 30 inclusive."
E0102 "Transmission DTC Fault Max Pressure Enablers" N/A "Different from row 3 to row 54 inclusive."
E0103 "Transmission Failsafe Enablers" N/A "Different from row 20 to row 54 inclusive."
E0104 "Transmission DTC Fault Pressure Modifiers" N/A "Different from row 0 to row 41 inclusive."
E1101 "Transmission Overtemp Threshold" 0.220264 "CAL: 131 ALT: 130"
E0801 "Slipping Trans Test Max TPS" 0.997955 "CAL: 100 ALT: 99"
E0802 "Slipping Trans Test Min TPS" -9.991760 "CAL: 10 ALT: 20"
E0803 "Slipping Trans Test Max Temp" -5.947137 "CAL: 130 ALT: 150"
F0507 "Convert Primary Sender to Volume" 3.953125 "Different from row 18 to row 128 inclusive."
G0103 "A/C Disable TPS" 10.000000 "CAL: 100 ALT: 90"
G0104 "A/C Enable TPS" -75.000000 "CAL: 0 ALT: 75"
G0105 "A/C Enable Timer" -2.929732 "CAL: 0 ALT: 12"
G1207 "Vehicle Platform Options" N/A "Different from cell: 7,8 to cell: 7,8 inclusive."
H0101 "Vehicle Speed Sensor Pulses per Mile" 1.993707 "CAL: 111684 ALT: 106633"
H0104 "Trans Output Shaft Revs/Mile" 2.527620 "CAL: 2790.0000 ALT: 2664.0234"
H0108 "ETC Speed Govern Threshold" -3.125095 "CAL: 98.0 ALT: 106.0"
H0109 "Maximum Vehicle Speed (Non ETC)" -3.125095 "CAL: 98.0 ALT: 106.0"
H0111 "Maximum Vehicle Speed (With ETC)" -3.125095 "CAL: 101.0 ALT: 109.0"
embs2001
Jul 23, 2017 12:54 PM
Kendall Campbell
Feb 20, 2016 12:47 AM
brandon_6667
Dec 28, 2015 12:54 PM
drexel
Dec 1, 2015 01:04 PM
Gorske
Nov 28, 2015 10:25 AM
