looking for OBD II serial cable
Old Jul 5, 2005 | 02:48 PM
renegade4e's Avatar
14 Second Truck Club
Default looking for OBD II serial cable
i've tried a brief search on ebay for a cable to connect my OBD II to my serial port on a laptop and didn't come up with much. anyone have any suggestions?
Old Jul 10, 2005 | 10:00 PM
Texas Terminator's Avatar
11 Second Club
what scan tool are you trying to use? call the manufacturer of the software first.
Old Jul 10, 2005 | 10:05 PM
02sierraz71_5.3's Avatar
I was thinking along the same lines before I bought hp tuners, didnt do any research on it but I believe you will have to make your own the software manufacturers dont sell them seperately for obvious reasons
Old Jul 11, 2005 | 01:12 AM
renegade4e's Avatar
any scan tool really. i just want a cheap and easy way of reading any codes my comuter is throwing.
Old Jul 11, 2005 | 06:31 AM
bart cox's Avatar
Here is a good one I have used http://obddiagnostics.com/
Free software download (you can dowmload and play around to see if you like it)
Build your own cable from parts and plans (real cheap) of but a cable ready to plug and play (still inexpensive)
Old Jul 12, 2005 | 12:16 PM
renegade4e's Avatar
thank you sir
Old Jul 13, 2005 | 01:10 AM
jfree81762's Avatar
Do they have a good USB version too(too lazy to search myself...)
Old Jul 13, 2005 | 06:44 AM
bart cox's Avatar
This is the information from the website
Question 12:
My PC doesn't have a serial port. What can I do?
Answer:
Some newer laptop computers don't have serial ports, but they do usually have at least one USB port. There are a number of converter cables available which also use a device driver program to create a serial port for these machines. Most of them do not work in DOS mode, but only for windows. The driver that comes with the converter cable must be compatible with your version of windows of course, and the USB ports must be functioning, both in hardware and in the operating system and in the drivers for the convertor cable. In general, obtaining a proper convertor and setting it up may require a bit of expertise and knowledge of your particular system. Some users have reported good results using converter cables, and a few have had problems with them. I won't be able to give you detailed instructions for the installation or checkout of these devices. If you have a port installed and wish to test it, these port testing instructions may be helpful.
(note: for port testing instructions, go to the website and go to the help section)
chvy=power
Oct 20, 2015 09:08 AM
GM1697
Sep 22, 2015 09:54 PM
DrX
Sep 18, 2015 08:53 AM
bisqikss
Sep 8, 2015 03:35 AM
