Locked TCC Torque Table
Old Jun 29, 2006 | 06:23 PM
MikeGyver's Avatar
Default Locked TCC Torque Table
I noticed this table has numbers less than 640 in it. Is it part of my lackluster performance? (Table Data)
And I noticed this table has my TCC locking in performance mode. (Table Data TCC)
If I raise the tq. table to 640 across the board, will it destroy the clutch? (I'm running 7psi boost)
And lastly, in HP Tuners Transmission Auto TCC Apply/Release-Apply/Release speed it lists Normal,Cruise,Hot, and Performance tables.
Does the PCM decide which table to use depending on how you drive, or must one of these tables be selected and applied by the tuner?
Thanks, Mike.
File Type: txt
TableData.txt (254 Bytes, 131 views)
File Type: txt
TableData TCC.txt (1,022 Bytes, 126 views)
Old Jun 29, 2006 | 06:42 PM
Zick's Avatar
As for which table it chooses goes like this;
Normal - everyday driving
Hot - When the trans temp reaches a certain temp degree
Cruise - when using cruise control
Performance - Tow/Haul button pressed
Old Jun 29, 2006 | 10:04 PM
MikeGyver's Avatar
By the way, this table is located in HP Tuners VCM editor, Engine,>Torque Management,>Maximum Torque,>vs. rpm. Click on the vs. RPM button, and the table shows "Maximum allowed engine torque vs. rpm whilst TCC is locked".
madmann26
Apr 29, 2020 09:17 AM
Cammed4ever
Sep 30, 2015 03:38 PM
Chevy305
Sep 28, 2015 09:21 PM
chopperloco
Sep 28, 2015 08:40 AM
g6t6o
Sep 26, 2015 10:57 AM
